587,675 active members*
3,449 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco PC Ultimax 3 software 1.6
Results 1 to 20 of 20
    Feb 2023
    4
    Colleagues! Please help.
    Bought in the UK Hurco BMC 30M, 1996 y.o.m
    However, it turned out that the hard drive was damaged.
    There are floppy disks in the black book, but the main one is also damaged.
    Perhaps someone has a distribution of Hurco PC Ultimax 3 software 1.6?
    Jun 2008
    1104
    Re: Hurco PC Ultimax 3 software 1.6
    Where are you?
    Sep 2016
    3
    I have the same issue but with 2.21 vmx24 I have first 3 disk installed but stuck on patch disk 010 . It's missing from machine book and I can't continue with installation.
    I have format d: drive by mistake.
    Maybe someone have some clone or install disk?
    I have also disk with backup of system files if this is helpful
    - - - Updated - - -
    Jun 2008
    1104
    Just skip the patch disk.
    Mar 2023
    1
    Thank you for your fast replay , i have skiped patch disk and now loader is trying to start but after while i get error that disk is not recognized . I hade same issue before when i have trying to boot computer with A and B floppy enabled in bios or without any floppy enabled. Now i have set every line in bios as before but same result.
    I don't have any knowledge of Hurco systems but seems that i'm missing something.
    Also in hurry i think i have messed up another working machine ( I have tried to copy files from another machine VM1 first to another desktop hdd and then to this VMC24 HDD and instead copy - paste i have used cut-paste . immediately i have returned copied files back on the drive but now machine is stuck with "Debuger detected in loader" - )
    Sometimes good day can be better
    Sorry that i'm using another user my phone battery is dead so i had to create new account on computer
    Feb 2023
    4
    Quote Originally Posted by bloke View Post
    Where are you?
    From Poland
    Sep 2016
    3
    I have fixed VM1 machine , just copied files in order HURCO.LDR first and everything is good now.
    On the other machine the VMX24 i have reinstalling the 2.21 update software from start ( skip the pach as advised by bloke ) and everything is going ok but on final prompt when computer ask for disk 1 to be inserted again , then picture and computer freeze ( keyboard not working ).
    After restarting machine now there is no any display on the monitors
    Computer looks like is working normally but not producing picture
    Anybody with similar problem
    Feb 2023
    18
    Quote Originally Posted by alsip_sc View Post
    If you can wait a week or so, I am taking delivery of the BMC30M floppies - I can try to get a copy for you.
    Jun 2008
    1104
    Be careful when updating software on machines with V2.21 software. It had a very specific security key option that only worked with that level of software. It was also a bit troublesome for loading the configuration files so don’t delete them.
    Jun 2008
    1104
    I can send V1.64 software via email. It just needs loading onto appropriately named disks.
    Feb 2023
    4
    Quote Originally Posted by scintam View Post
    Hello! Yes, of course I can wait!
    Feb 2023
    18
    Did you contact Bloke about this? As if he already has the software files, it will be much easier!
    If not, my floppy drive is arriving tomorrow and I will clone the disks. I have read that cloning bootable floppies may not be as simple as I hoped though.... so no promises!
    Feb 2023
    18
    Ok I have clones of the following. Which do you need?
    Ultimax 3 V1.64 - Disk 1
    Ultimax 3 V1.64 - Disk 2
    Ultimax 3 V1.64 - Disk 3
    Ultimax 3 V1.64 - Machine Configuration
    Optikey Utility Disk - Production Package
    Optikey Utility Disk - Probing
    BMC30/M Configuration (but this contains my leadscrew maps etc, unlikely to be suitable for you)
    Feb 2023
    4
    Everything from the list is possible, except for the last item. Can you send by email? Or maybe attach it here?
    Feb 2023
    18
    I have sent you a PM
    Hurco PC Ultimax 3 software 1.6 o superior
    se daño el disco duro, alguien tiene una copia del disco, o de los disketts para reinstalar el software
    Aug 2023
    1
    Hi
    I have same problem .
    Ilost floppy disk for hurco vmx 50 bcm 40
    Please send file until run machin again.
    Thank you
    Hello, is it possible for you to help me out too please ? I'm gonna have a heart attack because of the power supply here in Romania, looks like some software files were damaged because of this.. My "lovely" country Romania.
    Thank you in advance.
    Hello Bloke !
    Could you be so kind and help me with my BMC30 (YOM 99') Ultimax 3 with the software files ? Of course I'm willing to pay for your service sir. The machine didn't come with the floppy drives ...
    Thank you,
    Raymond
    Feb 2021
    1
    Do you have the 2.21 3 disk and patch disk?, can you share?
  1. hurco ultimax 2 help
    By msavcic in forum HURCO
    Last Post: 09-03-2020, 07:13 PM
  2. Hurco KM3P Ultimax PC Plus Software
    By techwreck in forum HURCO
    Last Post: 05-20-2017, 10:41 PM
  3. Need Help old Hurco Ultimax II
    By kabdelwahid in forum HURCO
    Last Post: 09-29-2015, 11:26 PM
  4. Ultimax 3 for Hurco
    By Nong Noy in forum Post Processors for MC
    Last Post: 08-16-2008, 04:02 PM
