587,584 active members*
3,896 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > GE Fanuc21i-T Geom/Wear It doesn't appear..
Results 1 to 4 of 4
    Jul 2022
    9
    Question GE Fanuc21i-T Geom/Wear It doesn't appear..
    Hello,
    Geom/Wear G54/G55/G56/... it doesn't appear.
    The only thing that appears when I press the offset key is [Offset ][Setting] [W.Shift] [Oprt]
    I guess this is from the turned off parameters.
    There is only offset on the offset screen. I can't get the tool zero. If anyone knows the parameter about it, I would be very happy.
    Mar 2022
    2
    Re: GE Fanuc21i-T Geom/Wear It doesn't appear..
    Here is the manual you need.
    https://www.fadalcnc.com/media/pdf/O...63610EN_01.pdf
    1202 bit 2 should be on shown on page 53,
    it looks like the position offsets are stored in 1221-1226 from page 54
    Hope that helps.
    Jul 2022
    9
    Quote Originally Posted by ChrisGlo View Post
    Hope that helps.
    I will try this on G54 G55 codes. But my main problem is Geom and wear doesn't appear, they closed it.
    Not sure I'm following. To start, there is no such thing as Geometry and Wear when talking about Work Offsets G54, G55, G56 etc. So no wonder you can't find them.
    Your Tool Offset Pages should be there. Have you tired the left and/or right arrows next to the Soft Keys at the bottom of the screen? Or what happens when you press the Offset Soft Key?
  1. Tool Wear
    By rckdef in forum Haas Mills
    Last Post: 08-09-2014, 01:32 PM
  2. FANUC 16-TB Tool Geom / Wear not Updating
    By ecapatto in forum Fanuc
    Last Post: 04-19-2012, 12:13 PM
  3. How to use Wear in Mach
    By gbpacker in forum Mach Software (ArtSoft software)
    Last Post: 12-10-2011, 12:17 AM
  4. Very Little Wear!
    By keen in forum Tormach Personal CNC Mill
    Last Post: 09-03-2010, 10:36 PM
  5. Fanuc21i-T - Reference point problem
    By Dare in forum Fanuc
    Last Post: 01-22-2009, 11:04 PM
