587,442 active members*
3,235 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Manually setting the current Work Offset with a variable
Results 1 to 16 of 16
    Jan 2023
    6
    Can someone please tell me how to set the current Work Offset manually using a variable?
    I need to do what G15 H=VC27 would do if it worked that way.
    As I recall, there is a way using VSOFT=VC127 or something similar, but I can't find it.
    Thanks!
    Jun 2015
    4156
    Re: Manually setting the current Work Offset with a variable
    hy joemach i never tried G15 H=variable, even when working with multiple wsc, but i believe you that it may not work i also searched for vsoft, but i could not find any details on it
    however, is possible to use multiple the origins, even if G15 is used only once inside the program
    i believe there are multiple fixtures, and you wish to restart after a random interruption ? please, in order to give a specific solution, i need more details on your setup / kindly
    Ladyhawke - My Delirium, https://www.youtube.com/watch?v=X_bFO1SNRZg
    Apr 2009
    1262
    What you are looking is for is VZOFZ[1]=123.456 or VZOFY[1]=123.456...
    They can be put into a program to set the work offsets if you like.
    You can find a lot more if you look in your manuals for the system variables.
    Best regards,
    Experience is what you get just after you needed it.
    Jan 2023
    6
    I have been looking through the manuals, but I cannot find out how to set the current value of "H" in G15 using a variable.
    I don't want to set the numeric value that is stored in "H", I want to select which work offset the OSP control is currently using, like if I set VC7=81 then wrote "G15 H=VC7" to get the same result as typing "G15 H81"
    I know that the above example doesn't work, but how would this be done on a Okuma OSP control?
    It sounds simple, but I cannot find how to do this in any of the Okuma Manuals we have and I've spent countless hours looking.
    Dec 2008
    3126
    Have you tried G15 H[VC7] ?
    Jun 2015
    4156
    hy joemach don't worry anymore, there are solutions, with different creation time, code size and impact on your existing program
    please, i need to understand what is going on, what made you look towards H=VC* maybe something can be done before g15 h= ? kindly
    Jan 2023
    6
    Quote Originally Posted by Superman View Post
    This is correct.
    I overlooked the easy way to do it.
    Thanks Superman!
    Follow up question.
    How do I see which is the current Work offset the control is using? (as in which G15 H# is active)
    I've looked at all of the position screens, looked in the manuals but I can't find it.
    Jun 2015
    4156
    hy joemach try vacod ...
    g15 h[vc7]
    vc1=vacod ( should return vc7 )
    please, how do you end up needing this custom initialization ? and from where do you know of vsoft ? kindly
    that is briliant superman i never used [] without + or =, etc; i wonder if N[] works, so to achieve programable adresses
    Jan 2023
    6
    Quote Originally Posted by deadlykitten View Post
    g15 h[vc7]
    Thanks, but is there a way to see what it is just by looking at a display on the control?
    Like on out Haas machines, I can look at the Current Position/Active Codes screen and it says "G154 P70" or whatever the current G154 is.
    One (hopefully) on last thing we struggle with on all of our Okumas:
    When we change a Subprogram and copy the new one into the control, the Main Programs still see the old one.
    Even if we completely delete the Subprogram from the MD1 location, the Main Program still "sees" it.
    How do we get the control to use the new one?
    The way it's always been done is to change the name of the Subprogram in the Main program so it's forced to use the new Subprogram, but I am 100% sure this is the wrong way to do it.
    They have been doing it that way here for years...
    Dec 2008
    3126
    try vacod ...
    g15 h[vc7]
    I believe VC1 should return the value held in VC7 (not "VC7")
    If you read the manual (I know that you don't), it says the square brackets can be used to separate the letter address and the string name. Same as a space is important when doing calcs etc within a program.
    Current WCS should be displayed on the position page, as well as the T#, D# H# N# (and sequence number)
    On the work offset page, it also should place an asterisk (LH side) on the active offset number
    Hint...
    N# and sequence number are 2 ways to restart a running program.
    N# restart will start on the selected line
    Sequence number allows a restart mid peck, or mid hole pattern for example
    I used to quickly check program syntax and graphics by using RS 999999 <write> to run the program on-screen only
    The grey matter is starting to have holes in it. Last used Okumas 15 years ago.
    Jun 2015
    4156
    Quote Originally Posted by joemach View Post
    hy joe pls share a photo of your screen, in automatic mode
    many use to still keep in MD1 folder the programs that are not curently used, and MD1 begins to act like an archive; in time, this leads to memory issue, and other stuff ... i alwasy keep only active programs in it, or i have it empty
    having many files can easy lead to duplicate content
    the controller will update it's references to subprograms only when you select the program, and not when you replace the files; in other words, you can select the program, then delete all files from MD1, and the machine will run just fine; it runs on flash memory, not on files from phisical hdd if this does not fix the issue, will try some test programs
    the moment you asked for editable G15 H, i thought that you are into some multifixture setup, and you lose progress, then you wanna restore fast ... but when you asked about inspecting the current G15, seems like there is a need for basic operation procedures
    next time i'll see you fly around, i'll throw a snowball at you
    if you read the manual (I know that you don't)
    if i remember, you where the 1st to send me to reading, but back then, even if i would, i could not understand; now is a different story
    just read the manuals got ya
    Jun 2015
    4156
    hello i only recently tried g15 h[vc1], and it worked, but also g15 h=vc1 worked
    i tried to apply it also to N, thus to make the jump " goto N [ VC1 ] ", but it didn't work
    Dec 2008
    3126
    Look at how you construct the actual string...
    N [ VC1 ] will be very different to N[VC1]
    N 123 is not legitimate code, unlike N123
    G15 H[VC1] is writing the H code after G15, before the VC1 value
    G15H=VC1 is writing it as G15 (VC value).... the H is replaced by the variable.
    Jun 2015
    4156
    at machine i write it ok when posting, i added spaces only to improve readability ... hmm
    i really thought i could macro also the N's with that trick of yours
    Aug 2011
    421
    it is impossible to assign any variable to N letter because OSP kernel isn't support it.
    "Imagination is more important than knowledge."
    Jun 2015
    4156
    instead of N=10, user task 3 allows :
    Code:
        V1=10 & GOTO V1
        IF [ V1 EQ 10 ] THEN GOTO V1
        IF [ V1 EQ 10 ] THEN G205
        IF LVTM THEN G=V1
        WHILE [ condition ] DO
    will make the code more legible
  1. Replies: 3
    Last Post: 10-19-2021, 12:27 AM
  2. Work Offset System Variable
    By Lucky12680 in forum Haas Mills
    Last Post: 02-27-2016, 11:12 PM
  3. How to manually set work offset for Z
    By JohnJW in forum Haas Mills
    Last Post: 01-12-2013, 06:09 AM
  4. Setting my Z work offset
    By Jaynboom in forum Tormach Personal CNC Mill
    Last Post: 02-02-2012, 06:14 PM
  5. G10 Work Offset Setting?
    By Wheelz in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-10-2010, 12:47 AM
