587,513 active members*
2,854 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Excitech routers > Help! I deleted the firmware from my DSP controller
Page 5 of 5 345
Results 81 to 82 of 82
  1. #81
    Oct 2022
    1
    Re: Help! I deleted the firmware from my DSP controller
    I bought a used machine that this same problem. Does anyone have advice how to fix it? I have RZNC-D5416 controller, would be thankful if anyone sent me manual how to use it.
    'Now when I change any settings, the DSP goes to "Cutting OFF the power to restart" and when I switch off the DSP and connect again, it shows, Z-Hart Limit. its going on processing, what shall I do.'
  2. #82
    Dec 2022
    1
    Quote Originally Posted by Big S View Post
    The DSP program can be reinstalled using the signtek software, (been there done that) you also need the software file( it should be something like 'Setup(RZTH501)_E_200721'
    Cenicero, can you pm me your email address and I will send you the English version of the host program. Its 6MB+
    Thanks,
    Shannon.
    Hi Shanon, I have the same problem that Carnicero. But I have not the Sintek Software. Could you send me it?
    Thank you so much
    VolcanoPincha
Page 5 of 5 345
  1. Opinions: Integrating Nikken 5AX-120 4th/5th axis on Excello 605 with Linux CNC
    By torinwalker in forum Uncategorised MetalWorking Machines
    Last Post: 04-16-2013, 06:44 PM
  2. I deleted the firmware from my DSP controller
    By ravafenice in forum Commercial CNC Wood Routers
    Last Post: 09-10-2011, 07:06 PM
  3. Deleted. NT
    By g-codeguy in forum MetalWork Discussion
    Last Post: 10-01-2008, 02:31 AM
