587,633 active members*
3,461 visitors online*
Results 1 to 3 of 3
    Sep 2010
    122
    770 spindle grief
    I have a 770 pcnc, it has been used very little. I turned on the spindle today and it changed directions all by it self. Nothing I do will reverse directions. Not even the manual control panel will reverse it. Anyone else encounter this??????????
    Sep 2005
    540
    Re: 770 spindle grief
    Not sure if this helps..... I have a PC1100 that developed a similar issue after a near by lighting strike several years back. It took out the interface control board.
    Have you checked cables and terminal connections?
    Robert
    Sep 2010
    122
    Quote Originally Posted by RTP_Burnsville View Post
    Robert
    Thanks for the response! I'm pretty sure the cables are ok. Also, I have since discovered, it will suddenly change directions indiscriminately. Also I am still using Mach3.
