587,787 active members*
3,048 visitors online*
Thread: Doosan M91
Results 1 to 3 of 3
    Dec 2019
    17
    Doosan M91
    Hello, I am working on modifying a Fusion post for my Hyundai lathe by starting with a Doosan/Fanuc post which seems to be close. I'm now stuck on trying to figure out what M91 is used for on a Doosan. My machine doesn't like the code, some I'm trying to find it and delete from my post with no luck so far. All I can find so far is it's used as an extra M code specific to the machine. Thanks in advance, Dan
    May 2007
    1003
    Re: Doosan M91
    We have an older Doosan Lynx (210LSY ?...not at work) and M91-M94 is available on that lathe. The last 3 Doosans list M91 through M94 as External Commands. I can't use them. I assume Doosan has reserved them for their use. I started using M91-M94 over 30 years ago on Hardinge lathes for their Safe Index programs for main and sub spindles. I use the same programs on our Daewoo/Doosan lathes. I changed the commands to M691-M694 on the new lathes. I set them in parameters 6071-6074 which call program O9001 through O9004.
    Can't help with your post. I've only used MasterCam. Hopefully someone with Fusion experience will come along and solve your problem. Good luck.
    Nov 2007
    364
    Re: Doosan M91
    Laser Tool breakage detection on and then off
  1. Doosan DNM5700S mills and Doosan TT1800SY machines
    By Green0 in forum Daewoo/Doosan
    Last Post: 09-09-2020, 12:30 AM
  2. Doosan
    By STARSR20J in forum Daewoo/Doosan
    Last Post: 01-30-2017, 03:29 PM
  3. Doosan
    By STARSR20J in forum Okuma
    Last Post: 01-27-2017, 03:48 AM
  4. M91 in nakamura tw-10
    By maximusek in forum G-Code Programing
    Last Post: 01-16-2008, 12:47 AM
  5. M41(M91) vs M470(M471)
    Last Post: 09-27-2007, 03:06 PM
