587,737 active members*
3,161 visitors online*
Results 1 to 4 of 4
    426 CB 1996 Bridgeport VMC1000-30 Backup
    Control LE426 CB
    Hardware tag
    Id Nr 312 002 29
    S. Nr. 6766-336 A
    Software
    280 472 15
    426 630 V04
    280 641 -16
    I am in dire need of a back up for this machine. We have two but one is missing two files and the other is missing the lst file. I'm certain that one is correct but without a way to read the bkp file I'm dead in the water. Any help would be appreciated.
    Is there any way to create an lst file?
    Any archive software other than TNCRemo to read a back up file?
    Thank you
    Re: 426 CB 1996 Bridgeport VMC1000-30 Backup
    Problem solved. You can reverse engineer an .lst file. Open the bck file, save as something other than your bck file. If you mess the bck file up you are toast. scroll to the end of the copy of your file and parse out all of the file names, follow the format in the lst file I have uploaded here and you should be able to access the bck file with TNCRemo.
    Consider this thread closed.
    Attached Files Attached Files
    Aug 2009
    1573
    Quote Originally Posted by KevinV_MEI View Post
    ...need a day Job?
  1. bridgeport vmc1000
    By bikeer in forum Bridgeport / Hardinge Mills
    Last Post: 07-24-2015, 11:46 AM
  2. VMC1000-30 BP W/HEIDH 426 Tool Pocket not returning to up position
    By KevinV_MEI in forum Bridgeport / Hardinge Mills
    Last Post: 06-13-2014, 09:26 PM
  3. Bridgeport VMC1000 with DX32 issues
    By djbouet in forum Bridgeport / Hardinge Mills
    Last Post: 04-06-2011, 05:14 AM
  4. VMC1000 HH 426 Reference Position
    Last Post: 03-02-2011, 12:42 PM
  5. Bridgeport VMC1000
    By Welshsteve77 in forum Bridgeport / Hardinge Mills
    Last Post: 08-09-2010, 10:03 AM
