587,468 active members*
3,078 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Mastercam 2022 2d dynamic mill on mach3
Results 1 to 3 of 3
    Dec 2021
    54
    Hi
    I have peoblem milling via 2d dynamic milling.
    I create toolpath for 2d dynamic mill while selecting default mach3 3 axis mill machine and it simulates well in mastercam then i generate nc file. After that i load that file in mach3 it shows on display strangely and goes out from table display
    I haven't that problem in 2d countour it works and post correctly
    Sending you pics in table display mood of mach3
    Can someone tell me what is the problem
    Attached Thumbnails Attached Thumbnails 20220628_005132.jpg   20220628_005357.jpg   20220628_011219.jpg   20220628_011228.jpg
    Mar 2008
    683
    Re: Mastercam 2022 2d dynamic mill on mach3
    Probably just the way the Mach3 controller is displaying I and J locations somewhere off the table. This is used for the math of the toolpath but not used for the actual toolpath. Can you send a sample of the G code. I can run it through my simulator.
    Nov 2013
    4524
    Mach3 uses incremental arc notation whereas you post is using absolute arc notation. Change the setting in the post and it will work fine.
    Craig
  1. How to get a Mach3 post proc. for Mastercam 2022 ??
    By Robert M in forum Mach Software (ArtSoft software)
    Last Post: 03-31-2023, 01:15 PM
  2. Mach3 post Processor for MasterCam 2022.... if existing ?
    By Robert M in forum Post Processors for MC
    Last Post: 06-12-2022, 03:54 PM
  3. SAVE THE DATE - SolidCAM World 2022 Virtual Summit - May 11, 2022!
    By PeteRoy in forum Trade Shows / Webinars / Other Events
    Last Post: 01-23-2022, 06:07 PM
  4. MASTERCAM DYNAMIC MILLING VID
    By brandou10l in forum Mastercam
    Last Post: 01-10-2011, 05:42 AM
