587,913 active members*
3,629 visitors online*
Results 1 to 2 of 2
    Meldas 60S Data Protecting
    I Have Meldas 60s Controller , In that i have Switch ON Machine edit key on Operator Panel . The Y238 and Y239 and Y23A Bits Got Enable by 1. Even though i am not able to edit the Soft limit parameter 2014. Edit Lock c Has been enabled that option also i am not able to edit. when i m trying to Edit setup Parameters Its shows Data Protecting. I have Switched the NCSYS Switch to 1 and checked even its not work. Kindly help..to solve the issue..
    Jun 2012
    36
    Re: Meldas 60S Data Protecting
    Hey friend,
    HAVE YOU SOLVED THIS ISSUE.
    SHEKAR
  1. Meldas 60s
    By Amar79 in forum Turning
    Last Post: 09-26-2018, 04:24 AM
  2. Meldas 300 Data Protecting
    By cncsooner in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-13-2018, 08:49 PM
  3. Mitsubishi Meldas 60S
    By BKCOM in forum Mitsubishi controls
    Last Post: 11-28-2016, 03:59 PM
  4. Parameter of MELDAS 60S
    By cbalasuriya in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-21-2016, 09:10 AM
  5. Meldas 60S
    By Slashy in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-02-2015, 06:41 AM
