587,402 active members*
3,026 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > A2-8030 isacon power control tech co ltd
Results 1 to 2 of 2
    Mar 2022
    1
    hello, I have an a2-8030 and I need to make it so that when I put power on it, it starts up and current comes out, so that as soon as I feed it, my motor already works, can you explain to me the steps to follow for that.
    or that when pressing a start button it is because it spends many days stopped and so that it does not consume energy while it is stopped and not have to open the cabinet for it to start.
    If anyone knows the device, could you tell me how I have to connect and configure the inverter.
    Thanks a lot.
    Sep 2021
    2
    Re: A2-8030 isacon power control tech co ltd
    They look almost the same, besides mine doesn't have a potentiometer and not having a data serial port.
    PN 01 Different
    thinking the above is to set RPM?
    PN 13 Different
    PN 14 Different
    I have attached the Config Parameters as well as the control ports pages to make it easier and as a reference. hopefully this will help guide others in the future when I have it sorted.
    Rent Karaoke Machines
