587,853 active members*
3,770 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Fanuc Compact flash pc editing tool for large programs
Page 2 of 3 123
Results 21 to 40 of 41
  1. #21
    Apr 2013
    13
    Re: Fanuc Compact flash pc editing tool for large programs
    Quote Originally Posted by Heavy_Metal View Post
    Yep, it works only on CF-Card (PCMCIA-slot).
    We have a FANUC 0i-MF but it works also on the 0i-MD, maybe also on the 0i-MC, not the 0-Model C or 0-Model D.
    What control do you have.
    Regards,
    Heavy_Metal.
    Thank you !
    What is the maximum size of the program can be used?
    I have this program, but there is no manual how to use it.
  2. #22
    Dec 2012
    395
    According FANUC 2GB, see attachment.
    We run some programs up to 3MB without problems.
    If you have the 0i-series I can make a BIN-file for you that you can try on a CF-Card.
    On our 21i-MB and 18i-TB it doesn't work.
    You didn't tell me what control you have.
    Regards,
    Heavy_Metal.
  3. #23
    Apr 2013
    13
    Thank you very much
    0i-MD & 0i-MC
  4. #24
    Dec 2012
    395
    Ok, the 0i-MD will work, the 0i-MC you have to try.
    When you have 400 program limit as standard on your control the max on the card will be 63 folders or files.
    The option 500 or 1000 folders or files in the card-program is an extra ( paid ) option, on Card side and control side.
    You need nc-files without extension, just like the M198 (CF-Card) option.
    Regards,
    Heavy_Metal.
  5. #25
    Apr 2013
    13
    Our main problem is editing cutting modes (feed and speed) in large programs. It is possible to do with FANUCPRG ?
  6. #26
    Dec 2012
    395
    Yes, thats possible, you can edit and change the code on control-side.
    After that you can drag and drop your new program back to pc via card-tool and save it on HD.
    For more info on this item you can also look on this Doosan forum :
    https://www.cnczone.com/forums/daewo...ck-5700-a.html
    Regards,
    Heavy_Metal.
  7. #27
    Mar 2017
    314
    Quote Originally Posted by Zub345 View Post
    Alternatively
    are you familiar with "F1" feeds
    Can be very handy in prototype/mold type work
  8. #28
    Apr 2018
    23
    Hi guys, Heavy_Metal solved this issue for me a while back. Turns out my CD copy of the pc editing tool was bugged. I can now drag files back off of the card and onto wherever I choose.
    Thanks again
  9. #29
    Hello everyone, can someone send me FANUCPRG.exe. Txc
  10. #30
    Dec 2012
    395
    Hey cnczone77,
    You need at least a Fanuc 0i-D series or a Fanuc 30i-32i series to run these BIN-files which are created by the program.
    Check the FANUC forum for more info: https://www.cnczone.com/forums/fanuc/412886-cnc.html
    When you have a 0i-D Series you need the A02B-0319-R642 ( 0i-TD - Lathe ) or A02B-0320-R642 ( 0i-MD - Mill ) to run these BIN-files.
    Activation of that R642 option is around €700,- / $850,- (USD) but you always can try a BIN-file before you want to buy the program.
    Program costs only €20,- in Europe, that's $24,- (USD), exclusive shipping, so pretty cheap
  11. #31
    Jun 2019
    11
    Hey cnczone77,
    Could'nt you share FANUCPRG.EXE???
  12. #32
    Dec 2021
    1
    Hi
    I have control oi md milling machine how can i use fanucprg.exe.
    With thanks
  13. #33
    Dec 2012
    395
    Quote Originally Posted by Ostacnc View Post
    Hi
    With thanks
    Check the Fanuc Europe channel or search on YouTube for: [ How to expand CNC memory quickly? ], the Program is really cheap.
    When your control has the [ MEM-CARD ] and [ MEMORY-CARD ] soft-keys you can use the program.
  14. #34
    Hey guys,
    What did you do to fix the "There is insufficient disk space" problem when trying to drag a file to desktop? I've tried multiple editing software disks that each came with our lathes and get the same error on all. Any insight would be much appreciated!
  15. #35
    Dec 2012
    395
    Do you run the edit program-tool straight from the software disk ?
    Be sure you run the FANUCPRG.exe file from Harddisk or USB-stick to drag files back to PC.
    Put the small software in a folder or an a stick and make a shortcut for it to your desktop.
    Regards.
  16. #36
    Regards.
    That's exactly what it was. I copied the .exe file onto the pc and now it works like a charm. Thanks very much Heavy_Metal!
  17. #37
    Dec 2012
    395
    You're welcome.
    Regards.
  18. #38
    Hello friend. I would like to test Program Transfer tool Fanuc software, could you post it here?
  19. #39
    Dec 2012
    395
    Quote Originally Posted by Cristiano_BR View Post
    I can make a BIN-file for you with the programs you want to test, main and sub, you can make a simple one just for a few tools.
    Your control needs the [ MEM-CARD ] and [ MEMORY-CARD ] soft-keys to run that BIN-file on the CF-Card.
    regards.
  20. #40
    Apr 2016
    1
    id be interested in a bin-file to test on my machine we have Fanuc Oi-MD controller and starting to get into CAD/CAM so files are getting large. also is there a vendor I can buy from in UK do you have link to purchase?
Page 2 of 3 123
  1. Replies: 11
    Last Post: 05-04-2021, 06:02 PM
  2. Fanuc Compact flash/PCMCIA HELP!
    By DeXtrous in forum Fanuc
    Last Post: 07-17-2016, 04:46 AM
  3. Replies: 2
    Last Post: 02-11-2016, 05:50 PM
  4. Fanuc Compact Flash to USB
    By Coyote553 in forum Daewoo/Doosan
    Last Post: 07-22-2011, 02:21 PM
