587,691 active members*
3,659 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Servo motor identification.
Results 1 to 7 of 7
    I have what seem to be servo motors. There are no stickers on the outside of the motors for identifying. I can identify is a Sumtak encoder of some sort. The connector seems to be a latch type. Thank you.
    Attached Thumbnails Attached Thumbnails IMG_1887.jpg   IMG_1891.jpg   IMG_1890.jpg   IMG_1889.jpg
    Jan 2018
    1516
    Re: Servo motor identification.
    Looks custom industrial from the likes of Omron or Phoenix.
    Motor looks pretty big.
    I envisage you having to take them off and use an alternative.
    Dec 2003
    24220
    They appear to be BLDC, if so the encoder may have commutation tracks on them, as well as the usual quadrature tracks?
    Albert E.
    DON'T MOVE THE "ENCODER". If you do, it could cost you more than it's worth to have it realigned, for proper commutation.
    Sent from my SM-N975U using Tapatalk
    Feb 2005
    750
    Quote Originally Posted by jittechnologies View Post
    Definately, dont move whatever it is. They are BLDC or "AC" servo's almost certainly, but without the MFG. spec.s, you will have a hard time trying to use them. There is no identification on the motor case? Bummer.
    Halfnutz
    Dec 2003
    24220
    Simple to do, but you need a double beam 'scope in order to align it easily.
    I have added a few to motors that either had failed or didn't have one in the first place.
    I replaced a few on Fanuc motors, which have a odd-ball, proprietary method.
    Albert E.
    Nov 2013
    4542
    even if you can identify the servos you have a problem trying to get compatible drives.
    Argon drives by Granite Devices for instance are servo drives made to accommodate a wide range of servo motors, but they cost over $400. Even then there is scope for
    mismatch between an unknown servo and an Argon drive.
    A brand new 750W Delta B2 series AC servo, drive and cable kit cost $435.......everything matches perfectly, no mess, no shagging around.
    Craig
  1. Servo identification
    By walter2 in forum Servo Motors / Drives
    Last Post: 08-09-2015, 06:07 AM
  2. Identification of a Servo-Motor Hitec HS-311
    By Susi in forum Servo Motors / Drives
    Last Post: 09-29-2012, 03:15 AM
  3. servo identification
    By cozz in forum Linear and Rotary Motion
    Last Post: 12-28-2010, 02:49 PM
  4. Clifton servo identification
    By rjreese29 in forum CNC Machine Related Electronics
    Last Post: 05-21-2010, 03:42 PM
  5. Servo motor identification help
    By kong in forum CNC Machine Related Electronics
    Last Post: 04-01-2004, 10:28 PM
