587,700 active members*
3,841 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Build Thread - Cielle Alfa 80 x 120
Results 1 to 6 of 6
    Jan 2012
    48
    I picked up a 20± year old Cielle Alfa 80 x 120 router and plan to do an electronics retrofit / upgrade on it. Still working out the details but I know it definitely needs an x-axis leadscrew. Even though it's an odd size it's probably all I can fit in my space, it was close and the price was right so that's fine with me.
    Here's a picture how I found it. That red guard thing is from another machine and didn't belong with it.
    Jan 2012
    48
    Re: Build Thread - Cielle Alfa 80 x 120
    Couple pics from today.
    Machine ID tag
    Removed some of the covers to get access.
    I think this lead screw has turned it's last
    The X-axis linear rails have some surface rust on them. I have a plan of attack so we'll see how it works out.
    Jan 2012
    48
    Little more progress. I soaked some blue shop towels in evaporust and draped them over the rails for a few hours. Took them off and then went to town with WD-40 and a green scotch brite. There were a few stubborn spots I had to hit with a brass wire wheel but overall not too bad. They look great and glide buttery smooth
    Also got a leadscrew and nut for the X axis.
    Feb 2005
    750
    "Che bella machina." You can tell everyone you have an Alfa. My Dad had an Alfa Romeo when I was a kid. What a car.
    Anyway, it looks like it should work fine, and has everything to be desired, linear guides, ballscrews, nice t-slot table, and hey-itsa Italian! Itsa gotta be good!
    Actually, imho, thats the perfect size for a wood router, 80cm x 120cm I imagine?
    Halfnutz
    Jan 2012
    48
    Yes, 80cm x 120cm. It looks like I can squeeze maybe 2 more inches out of the Y travel getting me closer to 3'; Havn't checked the X yet.
    An Alfa in the driveway would be NICE!! Classic though, not the new stuff.
    Jan 2012
    48
    Little more done.
    I tried to re-use the motor mount for the X axis carrier but messed it up so I made another one. While I had it off I disassembled the spindle of the nut drive and cleaned/greased it up and drilled it for the new bolt pattern for the lead nut. Also go the pulley drilled for the larger shaft on the new motor.
    Attachment 473258
    Attachment 473260
    Attachment 473262
    I also made some lead screw mounts. Seem to be holding fine and was able to re-install the carrier too. X-axis mechanicals are done; I left the lead nut un-attached so I could move the gantry around while working on it.
    Attachment 473264
    Attachment 473266
    Attachment 473268
  1. Cielle eta
    By osprey in forum Engraving Machines
    Last Post: 05-22-2016, 02:07 PM
  2. [Build Thread] Ballisticarmsco's G0704 build
    By BallisticArmsCo in forum Benchtop Machines
    Last Post: 12-08-2014, 09:06 PM
  3. Build Thread - 80/20 5X10 Woodworking CNC Build
    By jsantos in forum CNC Wood Router Project Log
    Last Post: 08-20-2014, 03:15 AM
  4. Mint's Build Aluminum/Steel Build thread.
    By FreshMint in forum Maintenance DIY Discussion
    Last Post: 10-31-2011, 04:18 AM
  5. Looking for advice a Cielle machine
    By legendboy in forum Engraving Machines
    Last Post: 01-23-2010, 08:44 AM
