587,744 active members*
3,936 visitors online*
IndustryArena Forum > CAM Software > Alphacam > Alphacam Automation: csv list to nested sheets.
Results 1 to 4 of 4
    Sep 2021
    2
    Hi Guys,
    We are using Alphacam 2020 including automation manager. I would like to automate our process where by we only route nested sheets with square panels.
    Process in Alphacam I would be:
    - Input csv file with number of sheets & length & width & thickness & ordernumber
    - automatically generate squares & cutout paths (using parametric sketches)
    - nest these squares incl toolpaths into sheets database
    - output all to default post processor
    - generate reports and labels for the sheets
    I think this should be possible with automation manager and parametric sketches but I cannot find where to start of how to link automation manager to parametric sketches function.
    Thanks in advance!
    Alan
    Jun 2015
    4160
    Re: Alphacam Automation: csv list to nested sheets.
    hy, i have no clue with alpha cam, but i can help you with a custom apllication, that will do what you want
    Sep 2021
    2
    Quote Originally Posted by deadlykitten View Post
    Yes we could do that too, but want to use Alphacam to take away the custom part. Custom applications only if all else fails.
    Mar 2022
    38
    For using constrained drawing in Automation Manager you need Automation Manager Plus.
    Rest of your requested points are soluble.
    Regards.
    Pavel
  1. Replies: 0
    Last Post: 08-04-2021, 10:31 AM
  2. Replies: 2
    Last Post: 06-29-2021, 05:43 PM
  3. Generate Geometry from Excel/CSV/TXT
    By DH2909 in forum Solidworks
    Last Post: 02-19-2021, 07:22 AM
  4. single program for many nested sheets scm routech 220
    By Benaiah in forum CNC Machining Centers
    Last Post: 07-26-2016, 01:06 AM
  5. Replies: 1
    Last Post: 06-14-2014, 10:57 PM
