587,517 active members*
3,324 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > how to run Yaskawa 3 phase 200V servo using 1 phase 200V?
Results 1 to 19 of 19
    Dec 2006
    130
    as above,
    am i able to use a external capacitor and leg it up to the 3rd power input L3?
    Re: how to run Yaskawa 3 phase 200V servo using 1 phase 200V?
    What is the specific model number you are looking at? SOME of the servos they make can be ran with 1ph power.
    Sent from my SM-N975U using Tapatalk
    Dec 2006
    130
    Mine was a SGDM 08ADA 200v
    Quote Originally Posted by jittechnologies View Post
    Quote Originally Posted by Syphonics View Post
    I'll have to look more deeply tomorrow. The only links I can find on this model looks like a scam site...yaskaaw? Nope... not gonna bite! Lol
    From what I see, you SHOULD be able to run it single phase. You MIGHT have to derate the drive. Looks like a 750w drive, 200v 1/3 ph. Do you have a drive you can hook up on a bench? This is to make sure it's not going to give you a fault for a missing phase.
    This is what I found...https://uploads.tapatalk-cdn.com/202...8b2c21b3c9.jpg
    Manual link...
    https://mobile.yaskawa.com/downloads...=SIEPS80000015
    Dec 2006
    130
    Hi thanks for the fast response, after hooking up with a 1 phase 240v , I got an AF1 error, which refer to a missing phase.
    https://uploads.tapatalk-cdn.com/202...7d0bca5e72.jpg
    Dec 2006
    130
    How do I derate the driver to allow 1 phase usage?
    On that drive, it is apparently not possible to run on single phase. The error is telling you there is a missing phase. The derating only applies if your drive will accept 1ph. If it WOULD accept 1ph, derating refers to using a 1kw drive on a 500-750w motor. Sorry to be the bearer of bad news.
    Dec 2006
    130
    Thanks, for the advise.
    Is there anyway to run the drive ; using a external capacitor will it work; or VFD?
    What is your application?
    Jan 2005
    15362
    Any Yaskawa 3Ph Drive can run on Single Phase you just have to wire it correct some of us are experienced some just pretend to know
    There would not be a Derating if the Servo Drive is larger than the Motor so a 1Kw would work well up to 750W motor no derating needed
    If the Drive has the same rating as the motor then you would have to derate it
    Mactec54
    Dec 2006
    130
    I have heard of that, but currently i am not able to the ways to wire the driver to allow 1ph usage.
    My application is mainly for my automation system.
    Jan 2005
    15362
    If you go to where your other post is you will find how to run it on Single Phase Post 31
    https://www.cnczone.com/forums/spind...-output-2.html
    Mactec54
    Yes, he can run it from an inverter, but I thought he was looking to run it straight off the line.
    Jan 2005
    15362
    He does not need an inverter and inverters are bad for Servo drives if will give them a much shorter life than normal
    Mactec54
    Jan 2009
    334
    as above,
    Hello Syphonics !!
    Try calling American Rotary.
    "American Rotary phase converters are perfectly suited for precision metalworking equipment such as wire EDM’s, CNC lathes, CNC mills, and other voltage-sensitive applications"
    https://www.americanrotary.com/application/machining/
    Hope this helps,
    Iron-Man
    Attached Thumbnails Attached Thumbnails American Rotary Phase Converter 640x551.jpg
    Jan 2005
    15362
    Quote Originally Posted by Iron-Man View Post
    Hello Syphonics !!
    Hope this helps,
    Iron-Man
    As I said he has it running on Single Phase there is no need for a RPC
    Mactec54
  1. Replies: 34
    Last Post: 08-17-2021, 07:16 AM
  2. Replies: 2
    Last Post: 09-24-2015, 07:04 PM
  3. 200v Three phase motor 4 poles
    By Dmed in forum Maintenance DIY Discussion
    Last Post: 04-12-2011, 01:03 AM
  4. Connect 200V servo motor to 400V drive
    By interflexo in forum Servo Motors / Drives
    Last Post: 04-15-2008, 07:34 PM
  5. Any controllers that can handle 140-200V servo motors out there?
    By mbwittig in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-28-2006, 08:14 PM
