587,453 active members*
4,395 visitors online*
IndustryArena Forum > MetalWorking Machines > EMCO CNC Machines > EMCO Lathe > Emco 325-II (Fanuc 21TB) live tool alarms
Results 1 to 4 of 4
    May 2016
    316
    Need some help with my 325-II (Fanuc 21TB) if anyone's run in to this problem or has an idea.
    Trying to use the live tools and I'm getting two alarms when I activate the M-codes.
    Commands:
    M52 (C-axis on)
    G97 Sxxxx M13
    As soon as the M13 (or M14) is called the live tool engages (I can hear the solenoid) and rotates 1/4 turn then it throws an alarm and the C-axis and live tool disengages.
    Alarms:
    8132 AXIS ACCESSED BY MULTIPLE CHANNELS
    8203 FATAL AC ERROR (0-PTR IPO)
    Both alarms are in the programming manual, but are cryptic:
    Cause: Internal error
    Remedy: Restart software or reinstall when necessary, report to EMCO, if repeatable
    I've re-started WinNC, no luck. Happens in MDI and during normal program execution.
    Live tools worked last year, but I haven't tried using them in about 10 months. No crashes or major problems/maintenance since they last worked.
    Maybe the G-code syntax is wrong? The Emco manual is pretty terrible...
    Anyone have suggestions?
    Thanks,
    Ralph
    Re: Emco 325-II (Fanuc 21TB) live tool alarms
    M5 before M52. I ran cross your post somewhere about tapping with live tools. I've only been successful with G33.
    May 2016
    316
    Quote Originally Posted by Diesel_Pilot View Post
    You're thinking this, right?
    M5
    M52
    G97 S5000 M13
    Doesn't make sense to me as it alarmed when I was using MDI one line at a time. The spindle wasn't running (in spindle mode), and I could do an M52 and then jog the C-axis just fine. It only threw up when I tried to engage the M13.
    But Emco is insane and anything's possible.
    After some serious searching, I found a single example in the Emco 21TB programming manual (ver C2003-7) on page D49
    G90 G40 G95
    T0909
    M52
    G28 G0 C0
    M13
    G97 S5000
    I wonder if the order is the difference? i.e. M13 on a separate line before the S-word.
    Thanks for the advice regardless of outcome. I'll have a go with both versions a bit later tonight.
    -Ralph
    May 2016
    316
    (SOLVED) Emco 325-II (Fanuc 21TB) live tool alarms
    Changing the g-code order and adding a pause did the trick.
    M52 (C-axis on, also homes C-axis so no need for)
    M13 (live tool CW)
    G4 X1 (needed pause before the speed command. No pause = alarm)
    G97 Sxxxx (spindle speed)
    Subsequent speed changes or start/stop/reverse don't require a G4 pause as long as the M52 is active.
    Now I've just got to try editing my post so it outputs correctly.
    Thanks for the help Diesel_Pilot!
  1. Takisawa TC-10 Fanuc 21TB
    By ace of spades in forum Fanuc
    Last Post: 06-19-2022, 05:38 PM
  2. 325-II Fanuc 21TB programming
    By spumco in forum EMCO Lathe
    Last Post: 12-29-2020, 01:44 AM
  3. error EMCO 325
    By amtecannecy in forum SIEMENS -> GENERAL
    Last Post: 06-25-2018, 08:21 PM
  4. strange emco 325 issue
    By ratedr in forum EMCO Lathe
    Last Post: 11-20-2016, 04:29 AM
  5. Post for Daewoo w/Fanuc 21TB
    By ProgSol in forum Surfcam
    Last Post: 03-11-2011, 10:05 PM
