587,104 active members*
4,334 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Safety speed monitor error / MSM module error
Results 1 to 2 of 2
    May 2012
    Exclamation Safety speed monitor error / MSM module error
    Hello everyone
    We have okuma MA-60HB and for three days we have problem with safety speed monitor.
    Alarm shows just after osp is booted. We have two MSM modules that I think are responsible for monitoring the speed.
    The second one (responsible for ATC and APC) LCD shows blinking oP / e2
    I think the e2 describe some kind of error but we don't know what.
    I also change module for another one and still it’s the same.
    Maybe someone have papers for MSM module? Any idea what is causing the alarm.
    Strange thing is that when we turn on machine with emergency stop its working fine. But if we turn it on normal there is an alarm from the beginning.
    After we start with emergency stop button machine works normal.
    I tried to find what axis is causing an alarm. I am not sure but it's probably APC motor no 2 which is operating normal.
    Please help! :]
    May 2021
    1
    Quote Originally Posted by filipgd View Post
    Hello everyone
    Please help! :]
    Hi, we have the same problem. Did u find a solution?
    Thank you
  1. Flash CPR error code 1430 module 151
    By ktdan in forum GibbsCAM
    Last Post: 12-21-2012, 04:08 PM
  2. Alarm 23 - excess error (speed)
    By hotrob1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-21-2012, 04:38 PM
  3. Rapid Speed / Following Error
    By Bob La Londe in forum HURCO
    Last Post: 01-20-2012, 06:21 AM
  4. 1097 Safety Speed Monitor error
    By Søren in forum Okuma
    Last Post: 11-04-2010, 08:01 AM
  5. G320 Error Monitor - now with better photo!!!
    By MattTheNoob in forum Gecko Drives
    Last Post: 09-26-2009, 02:36 AM
