Originally Posted by
Geof
But my point is you have to effectively build the alternative to hold all your bolts, reinforcements/attachments, mounting "devices" in the correct place within the mold in which you then cast the epoxy. And if you do not get everything in the correct place you are stuck because you cannot rework the epoxy.
But I would assume that all the "bolt ons" would be adjustable in position anyway. Seems crazy not to do so.
Surely the whole point of the EG is to give a well damped, simplified(!!) constructional method for frames etc.
Just my groat's worth though.
John
It's like doing jigsaw puzzles in the dark.
Enjoy today's problems, for tomorrow's may be worse.
