587,249 active members*
3,552 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC "do-it-yourself" > Milli a new composite mill kit
Page 31 of 109 2129303132334181
Results 601 to 620 of 2170
  1. #601
    Jul 2018
    6462
    Re: Milli a new composite mill kit
    Hi Ard - You need to build a dummy spindle and tool so the applied load is at at typical tool load point. make the tool very stiff so that is out of the equation for now. I have a "rigid" setting in my materials. Its an infinitely stiff material and I set the tool to that. The spindle can be steel as it is steel.... some images would help. I apply the load to the bottom of the tool surface. Peter
    The dark blue parts are "rigid" the yellow arrow is where I'm applying the load usually 1000N. The post and cone are there so when loads are applied you can see what is happening at the tool.
    As a general design point - The static stiffness of a machine is not what happens in practice. This is called the dynamic stiffness. The tool and the job and the cutting point is intimately connected. If the tool moves so does the job either by deflection or by material removal. If the tool is doing its job it chomps away happily at the material and it must be a small oscillating motion. If its skipping and missing cuts then its chattering. Plus the force of operation is not at the tool. The tool as we model it is a reaction not an action. The force is applied by the motion system and has to find its way to the cut site. So in summary the static stiffness physical test is an approximation that is easy to do to establish the apparent stiffness of the machine. We know that machine stiffness and performance are connected but we maybe testing it the wrong way, but its what we have at the moment...
  2. #602
    Sep 2014
    129
    Milli always seems a bit over sized/weight, so why not go all the way and transform it into a "floor top" machine?
  3. #603
    Jul 2018
    6462
    Hi Klaas - I thought about that the other day actually. But it gets away from my customer base of DIY/Makers etc. And it starts to compete with "real" mills so I think its scale down not up. I'm about to review the whole thread, collate the good and bad bits and have a deep re think... Stay tuned. Peter
    Hi Klaas - Its actually undersize & underweight for the size of the table when you compare to commercial mills. I do like machines you can walk on. Maybe a new class of Maker grade mills "walk-in" size.... or jumbo Maker class. In printers they have "large scale" printers but the "scale" keeps changing. Its all getting bigger and bigger.... if I went to FLOOR SCALE I think I'd go back to a gantry machine. Take up a car space??? They say to always think BIG. Peter
  4. #604
    Jul 2018
    6462
    Evening all - Moved the LHS stuff to the painted RHS side today. I sanded the painted side with my 5" orbital just knocked the pips off. Tomorrow paint the LHS. Then get some infusion VE or may use my infusion epoxy to do the topcoat. Didn't like the laminating VE, too thick. But it works in the end. Plan to have everything on wheels... Peter
  5. #605
    Jul 2018
    6462
    Hi All and Sundry - Up early to do the floor before it got hot. But stopped early as I ran out of resin. The pail says 20kg but I only got 18.3kg out of it. Have to talk to the supplier next week. Upsetting, that puts me behind schedule to get the floor finished.... Peter
  6. #606
    Sep 2014
    129
    Bummer Peter, OTOH be glad with your new shop, I can only dream of such a space.
  7. #607
    Jul 2018
    6462
    Hi Klaas - Yes I'm very lucky to have a spot like this. I rechecked my resin tally and its correct. I did not carry over a couple of figures correctly in my weighing tally so I actually used 19.7kg and there's a smear of 400g in the pail. So will finish the floor asap... Will look at moulds for the CSA tomorrow can do some casts while waiting for more resin. Peter
  8. #608
    Jul 2018
    6462
    Project Summary
    Milli Initial thoughts (Metal Mill)
    BT-30 spindle, 500x500x500, 20N/um model stiffness, target actual stiffness >10N/um
    composite for superior damping, make as many parts in-house as possible, benchtop mill
    Milli-No1 lifting gantry config – too complex
    Milli-No2 – moving column fixed table
    Milli No4 – moving column moving table 650x300x450
    Milli No4 lifting gantry
    mucked about 15mm rails vs 20mm rails. Should go to 25mm rails
    Milli No5 – moving column moving table – seemed to be firming up
    Chasing cast material stiffness – need 70GPa plus EG too low
    What spindle speeds and power to use? Lots of discussion here. Decided on 750W and 1000W AC servo. Small frame 80mm
    Milli No6 tombstone column - moving table
    So far its been a struggle to get torsional stiffness inot the column. This struggle continues
    Ralph chirped in with his actual machine stiffness and machine model much appreciated....
    back to basics – and some generative design. Sdtill no breakthrough. Discussion onh FE modelling cars and rails
    Milli No8 – moving column -moving table. Quite big machine now
    Milli No9 – mainly base development. Got thicker and thicker. The column got bigger and bigger
    Milli No10 – moving column moving table -hit the stiffness target – maybe this is it and I just kept going?
    Much discussion on materials
    Milli-AL a plate model - moving column
    CSA shows up. 2020-11-19
    Milli-No13 lots of work on materials, damping and fibres
    Milli No14 CSA spindly column moving column. Column rosional stiffness is the key and it continually is the common theme and hurdle
    Mili No15 moving column moving table with saddle fixed table
    Milli No16 shapely column CSA
    Milli No17 worked on getting the bolts in and assembly logic correct
    Milli No19 moving column on saddle 3 rails...
    Milli No20 quite detailed and developed
    Milli No21 started to consider metal inserts and other deatisl. Well developed....
    More base development
    UHPC apperaed 2020-12-10
    Milli No22 more CSA but more steel – yuk
    Milli No23 vibration analysis
    Mill-G was a moving gantry design.. Much more discussion on materials
    Milli-M M was for Moris config. Called it the headstone config. Lots and lots of materials discussion
    2020-12-25 ralph provided step file of Mikinis machine very useful
    I decided to make the machine smaller and use an ER17 power head. Machine still not small enough!!
    606 posts and still no resolve on the basic design
    Common theme is poor torsional stiffness of any of the columns designed. The smaller the machine to more , material stiffness is needed... EG has poor stiffness, need advanced cold casting material??? E80 is out there but available to me... rethinking in progress. Peter
  9. #609
    Nov 2020
    361
    Make a proper cast iron part and work backwards from that. Maybe that will give you some ideas.
  10. #610
    Jul 2018
    6462
    Hi Ard - Cast Iron is out as I can't do that myself... cheers Peter
  11. #611
    Nov 2013
    4491
    that's why God invented foundries, so you can cast stuff without having to do it yourself.
    My experience is that it's not cheap but the result is superior.
    Craig
  12. #612
    Aug 2005
    205
    Nice digs Peter!
  13. #613
    Jul 2018
    6462
    Hi Craig - Foundries are a dying trade. Not saying that they are wrong just in a few years printing will replace most of that and CI will die out from machine tools as well. Composites will replace them, printed or RTM or cold cast so may as well get on the bandwagon now. I could make Carbon Fibre parts cheaper then CI parts maybe if the volume was there. Have to look at that in more detail....Peter
    Hi Marv - Thanks a few visitors have said they want to move in.... but sorry its a workshop not a batch. Peter
  14. #614
    Jul 2018
    6462
    Hi Ard - Here's a cast iron kit. I think you mentioned about buying a kit? Peter
    https://allcncrouter.com/collections...mill-frame-kit
  15. #615
    Nov 2020
    361
    Quote Originally Posted by peteeng View Post
    No, what I meant is once you had a cast iron part that meets(exceeds) your specs, with the same wall thickness all around the part, etc, you could work backwards from that to replace it with a steel assembly, for example. It would give you a hint where material is needed and where its not, of course you could do a generative/topology optimizations instead too, but that thing gives results that can't really be replicated with anything other then powder printing, but it would still give you a hint.
    So cast iron but only virtually, is what I meant.
    You also mentioned something about an ER motor? so out with the BT30? Got any particular one in mind?
  16. #616
    Jul 2018
    6462
    Hi Ard - The spindle has currently three options 1) ER17 2) BT30 and 2) high speed router spindle.... the ER and BT motor will be a 80mm (or 90mm) frame 750W or 1kW option AC servo. See images of power heads attached.... Peter
    Since the column has been the hurdle so far my thoughts are to return to the gantry style to remove the column. The machine would run "along" the bench and be a lifting gantry design to remove the saddle. The columns would be fixed and it would have a moving table. The only negative I see is that the table drive is in the muck. Sort of been here before but that was also before CSA so need to sort out the CSA casting stiffness. Re Your comment about designing in CI then converting to steel. I have sort of been doing that. I design the geometry to what I think is needed then change the material from EG E40 to AL E70 to steel E200 to see what makes a delta. If steel doesn't do it then its back to changing geometry. A new possibility has arisen in that a customer of mine has mentioned he has a working 10"x5" commercial router in a warehouse doing zip. I can work contra to get access to it. This means making large aluminium parts (or machining lands on cast parts) maybe within reach at a reasonable cost. Early days on that possibility. Its a 2 hours drive away so means I need to learn its system and spend a good day to get value out of it... But maybe a good thing. Peter
  17. #617
    Nov 2020
    361
    I've read bad reviews of those green cartridges so make sure you know what your getting into. There's a blue version from a different company that seems to be slightly better.
  18. #618
    Jul 2018
    6462
    Thanks Ard - I'm sure there is a quality grade per cost. Once I get the structure settled I can investigate that issue. So green is bad blue is good
    Maybe a different one will show up. A round type or maybe Martec will build me a few blue ones. Peter
  19. #619
    Jun 2007
    3891
    They are all pretty poor. they have radial bearings and most are good for 2000-3000rpm - a few say 6k but i wouldnt.
    They are not what you buy when you go to the effort of building a nice machine frame. they are what you buy to bolt to a sheet a plywood to stick a grinding wheel on.
  20. #620
    Jul 2018
    6462
    Morning IHNF - Thanks for the heads up. Can you suggest a suitable supplier? Cheers Peter
  1. WillMill - HSM Benchtop Composite Mill
    By Williamlii in forum CNC Wood Router Project Log
    Last Post: 05-31-2020, 07:03 AM
  2. Replies: 1
    Last Post: 07-11-2018, 04:14 AM
  3. Composite Mini Benchtop Mill / Router
    By ficklecycler in forum Benchtop Machines
    Last Post: 06-01-2018, 12:22 PM
  4. Looking for some composite routing
    By Locster13 in forum DIY CNC Router Table Machines
    Last Post: 11-02-2006, 05:20 PM
