587,597 active members*
3,665 visitors online*
Results 1 to 4 of 4
    Nov 2009
    19
    Reset c after disengage
    He guys.
    I'm wounding if it is possible to get my machine to reset c-axes cordinat when disengaging it.
    Today I have to rewind it to zero before disengage which can be quite time consuming.
    It's a lathe controlled by fanuc 18i
    Sep 2005
    281
    Re: Reset c after disengage
    On my samsung SL-65MC with fanuc 0i I will program a G28 H0; M5 that way it will zero out before it disengaging. I like having a zero in C on the screen when I'm not using C axis
    Is C axis the spindle or a real servo?
    Nov 2009
    19
    G28 h0 did the trick.
    Sendt fra min ANE-LX1 med Tapatalk
  1. Replies: 27
    Last Post: 04-08-2022, 03:05 PM
  2. Optional Stop will not disengage!
    By jupiteral in forum Fadal
    Last Post: 05-23-2014, 06:54 PM
  3. Z Axis disengage mechanism
    By hcrotalus in forum Uncategorised MetalWorking Machines
    Last Post: 08-31-2011, 08:07 PM
  4. How to disengage gear at limit, What to use?
    By bigalexe in forum Linear and Rotary Motion
    Last Post: 05-26-2010, 08:45 PM
  5. BOSS 8 Drivers Automatically Disengage
    By Nick93539 in forum Bridgeport / Hardinge Mills
    Last Post: 06-06-2008, 09:32 AM
