587,655 active members*
3,785 visitors online*
Page 2 of 253 12341252102
Results 21 to 40 of 5053
  1. #21
    Mar 2005
    1136
    Quote Originally Posted by walter View Post
    Larry, we may be onto something here
    Our home made machines are growing in size, it takes ridiculous amount of time to weld these silly structures...
    I had never thought of an epoxy granite structure as replacing a steel fabrication, its not strong enough imo, the yield stress is much lower than steel or cast iron irrc and the modulus of elasticity is about 1/6. saw it more as a way to stop a fabrication ringing like a bell. commercial practice suggests the same, where I have been able to see commercial uses for epoxy concrete, it is either filling the voids in a CI or steel structure OR use as a heavy base for machines deploying negligible forces, ie optical equipment. I would not make a metal working machine just of epoxy concrete, not unless a lot engineering calcs proved my assessment wrong. don't forget to normalize any fabrications going into a machine
    Yes, some of these compounds have incredible properties (vs cast iron) but we're trying to solve some very "basic" problems here.
    Larry you mentioned earlier 50X better than steel and 10x better than CI for epoxy/granite's vibration dampening abilities, seems high to me. I'd read CI is 1x better than steel and Epoxy granite 50% better than CI. Not that easy to find info on the subject though, after all vibration is a magnitude and a decay, its not straightforward, at least to me, what better means, but 10x seems high.
    thanks for all the good info being posted on the subject, I continue to believe it holds promise for high end diy machines
  2. #22
    Jul 2005
    12177
    Quote Originally Posted by Mcgyver View Post
    ...Larry you mentioned earlier 50X better than steel and 10x better than CI for epoxy/granite's vibration dampening abilities, seems high to me. I'd read CI is 1x better than steel and Epoxy granite 50% better than CI. Not that easy to find info on the subject though, after all vibration is a magnitude and a decay, its not straightforward, at least to me, what better means, but 10x seems high.
    This page has the numbers claiming better damping characteristics:
    http://www.accurescasting.com/polymer.html
    On other pages I found some rather unbelievable claims for casting accuracy such as +/-0.0005".
    But they do refer to 'machine bases and support structures' so they are not talking about using this stuff for the entire machine.
  3. #23
    Jun 2003
    2103
    Then I guess this machine won't work!
    Here is the story link.
    http://www.machinedesign.com/Content...MecRG02-01.jpg
    Mike
    No greater love can a man have than this, that he give his life for a friend.
  4. #24
    Jul 2006
    1256
    non toxic
    Walter
    Epoxy is only nontoxic after full cure, one week.People tend to think it is not toxic as it has no flamable solvents.Epoxy can pass through your skin.Wear gloves and mask if sanding.
    Larry
  5. #25
    Jul 2005
    12177
    I found this page which gives a lot of answers that lead me to conclude this is not a technique that can be readily adapted to DIY; considering you first need to make a very precise steel mold and the material cannot be worked after casting.
    http://www.itwpolymercastings.com/faqzanite.html
    But the materials are not difficult to find:
    "Zanite® polymer composite is a blend of pure silicon dioxide ceramic (99.8%) quartz aggregate, specially formulated high strength epoxy resin and selected additives. The natural elliptical shape of quartz is ideal for casting intricate structures."
    In fewer words; sand and epoxy.
  6. #26
    Jul 2006
    1256
    Mcgyver and Geof
    I have to agree, I cant see a hobyist building an entire machine ofE/G.For us hobbists we can use it for table tops,machine bases and weldment filling.Yes there are commercial machines totally composites, made in molds.
    I would hate to think what would happen if a forklift bumped into a 100% polymer machine
    Larry
  7. #27
    Jul 2005
    12177
    Quote Originally Posted by lgalla View Post
    ...I would hate to think what would happen if a forklift bumped into a 100% polymer machine Larry
    I would hate to think what would happen if a forklift bumped into any machine!!(chair)
    But I do have a question: You say; "there are commercial machines totally composites", are there really? All I have read refers to machine bases not the full machine.
  8. #28
    May 2003
    792
    I had never thought of an epoxy granite structure as replacing a steel fabrication, its not strong enough imo, the yield stress is much lower than steel or cast iron irrc and the modulus of elasticity is about 1/6....
    Good point.
    Then again, folks here don't build metal working CNCs. 90% of these machines are destined for wood, mdf, foam, plastics, aluminium.
    I'm into wood machining, and really dislike the idea of steel tubing, welds, drilling. Fastening together 800 lbs of tubing would take months! I even hate the smell of it
    I just need the basic rigidity and level- I'll go with (reinforced) concrete type of material.
    Thanks for all the replys- you guys are the best!
  9. #29
    Jun 2005
    1436
    Mike - could you revise the link to that story in #23 as your link is only to the picture.Thanks
    John
    It's like doing jigsaw puzzles in the dark.
    Enjoy today's problems, for tomorrow's may be worse.
  10. #30
    Jan 2007
    10
    Found more Polymer Concrete
    http://5128.rapidforum.com/topic=110...6&search=beton
    try this link. German cnc site. Just look at those pic's. Looks Good
    Attached Thumbnails Attached Thumbnails T6765_110773689090_Portal7.jpg   T6765_110773689090_Portal6.jpg   6765_110773689090_Form4.jpg   T6765_110773689090_Porta2.jpg
  11. #31
    Jun 2005
    1436
    schrupphobel72 - Your last three images are corelpaint (?) could you make them jpegs so we can enlarge them.
    Not sure about the link as I don't read German -it's a forum, I think ?
    John
  12. #32
    Jul 2006
    1256
    Bad News
    And now for the bad news, cost.
    Lets assume$50/gal for epoxy,10 cents a pound for sand.I will round off to the nearist numbers.
    To simplify things we will try 33 1/3 % epoxy/sand.
    1cu/ft epoxy=7gallons =70lbs=$350
    1cu/ft sand=166lbs=$16.60X2=$33.20
    Now we take 1 cuft epoxy and 2cuft sand and have our33%to66% ratio
    So the cost for 3cuft=$350.00+33.20=$383.20
    Cost per cuft.=$120.00
    Weight of 3cuft 402lbs
    Cost/sqft=$10.00
    Our 3cuft at $383.20 gives us 32sqft one inch thick.
    Looking back to post #10 from Episs we are close to the same price and weight
    More calculations for my 6'X12'X4" router table.Lets see 72sqft4"thick=280sq ft X$10=$2800.00 Total weight 3080lbs
    Larry
  13. #33
    Jun 2005
    1436
    Larry - Why not use a layer of patio paving slabs as the top, epoxied together, then coat that with 1/4"skin(or even less?)
    John
  14. #34
    Jun 2005
    1436
    Build a torsion box out of paving slabs ?
    John
  15. #35
    Jan 2007
    10
    attached the pic's from the german site again
  16. #36
    Mar 2005
    1136
    Good point.
    thats part of it - different paradigm - no doubt we're visualizing two very different machines! its building metal working cnc's that interest me, I have little interest in wood machines for now. my thoughts were that a heavy weldment, using structural shapes could be filled with E/G and you'd have a chance at a metal working machine, small work envelope but very heavy and rigid. still, from I've been able to learn, its advantage over steel/CI is in vibration dampening, not strength or rigidity.
  17. #37
    Jun 2003
    2103
    Quote Originally Posted by greybeard View Post
    John
    http://www.machinedesign.com/ASP/vie...MDSite&catId=0
    Sorry about that.
    Mike
  18. #38
    Jun 2003
    2103
    I guess my first post wasn't clear enough. The only thing on the structure of this machine that is metal is the bed. Go read the info about it. It is a metal working machine made almost entirely of the PC you have been discussing here.
    If you search you will find many articles about metal working machines that have been made that hold better tolerences because they are built of PC.
    Mike
  19. #39
    Jul 2005
    12177
    That is the link that claims a casting precision which I find hard to believe. Here is a quote:
    "A mixture of reactive, high-strength resin and mineral aggregates makes as-cast machine components to 0.0005-in./ft flatness, with hole diameters to ±0.0001 in., and feature dimensions to ±0.0005 in./ft."
  20. #40
    Nov 2005
    25
    At my last job we did some experiments with replicated surfaces using epoxy based materials. What we found was that we were able to produce replicated surfaces, using a large granite surface plate, with a flatness within .001" over about 3'. The biggest problem we had was the hardness of the surface. We were running an air bearing over the surface. If any grit got on it tended to get stuck in the epoxy and could end up scratching the way or worse the bearing.
  1. Replies: 71
  2. Replies: 14
  3. Replies: 9
