Re: Size of image-object cut too small using Inkscape, Makercam then Mach 3
Originally Posted by
JONLE
Thank you for the reply. I loaded 5" X 10" , file, ran a test cut and it was really small, my dros showed the correct measurements, got me to thinking about possible lead screw-motor problem. I re-calibrated my X-Y-Z axis steps per unit three times with different distances, problem solved.
I may not have discovered the problem with out your input.
oops I named that file wrong.
5" x 10" should have been named 10" x 5"
10x, 5y
I think you figured that out
Anyone who says "It only goes together one way" has no imagination.
