587,829 active members*
2,985 visitors online*
Results 1 to 4 of 4
    May 2008
    266
    Edit Causes TNG2 to Freeze
    I'm learning to use Deskproto, which compared to my other CAM software creates many short G01 moves and so files are much bigger.
    The attached file causes TNG2 to freeze if I load it and then try to use the Program > Edit function.
    I suppose I might not be waiting long enough, but when compared to how quickly the same file loads into TNG, then it seems something may not be quite right.
    Many Thanks, Martin.
    Mar 2017
    1332
    Re: Edit Causes TNG2 to Freeze
    It does not freeze. It just takes very long time.
    G-Code editor was not designed for large g-codes. Syntax highlighting is slow.
    May 2008
    266
    Quote Originally Posted by PlanetCNC View Post
    Ok, thanks for replying, I can see than now.
    Could it be speeded in the future?
    Martin.
    May 2008
    266
    Now fixed in latest update. Files open in the editor instantly!
    Thanks very much.
  1. NM-145 - Mach 3 Random Freeze - Help
    By EELSON in forum Novakon
    Last Post: 03-30-2019, 08:20 PM
  2. Steppers freeze
    By johnmark in forum Stepper Motors / Drives
    Last Post: 02-24-2017, 11:32 PM
  3. Okuma post edit or CAM edit?
    By dfearnow in forum Okuma
    Last Post: 12-30-2015, 11:47 PM
  4. Sprutcam 9 Alt-Tab Freeze
    By wtopace in forum SprutCAM
    Last Post: 07-06-2015, 09:47 PM
  5. Computer Freeze
    By rweatherly in forum Machines running Mach Software
    Last Post: 12-06-2006, 08:56 PM
