587,193 active members*
3,171 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Proximity Sensor Wiring Issue? Help needed.
Page 4 of 4 234
Results 61 to 68 of 68
  1. #61
    Mar 2007
    2083
    Re: Proximity Sensor Wiring Issue? Help needed.
    Hi Ronald
    use the 24V supply as the G540's 48V supply is more than the sensors 6 - 36V supply range
    as the sensor has a N/C NPN output you can only connect one sensor directly to each G540 input
    the G540 input circuit consists of the LED within an opto isolator that is connected in series with a 2200 ohm resistor powered from a +12V supply
    when an input is grounded approximately 4.5 mA will flow from the G540 input to ground
    you can measure this with a multimeter connected between the input and G540 ground
    (the current is limited by the 2200 ohm resistor inside of the G540)
    John
  2. #62
    Sep 2008
    148
    So basically I had it hooked up correctly the first time I tried but instead of a 24V Wall Wart I had used a 9V Wall Wart. When I did that though the Probe would light up until I turned the Controller on and then Shut Off and not detect anything. I'll give it a go with the 24V Wall Wart.
  3. #63
    Mar 2007
    2083
    provided the sensor has an NPN open collector output so there is no components connecting the + supply to the output
    you can check this by powering the sensor and measuring the voltage between the blue ground wire and black "output" wire
    an output near 0V will indicate an open collector output
    this is what you have when a sensor with a NPN open collector output is connected to the G540 input 1
    Attachment 438464
    if the voltage between the sensor black output and blue ground/ 0V is more than 12V and possibly
    a voltage near to 24V will indicate an internal pullup resistor connecting the +24V supply to the output
    in this case you will need to use a diode to connect the sensor to the G540 input
    the diodes anode goes to the G540 input and anode to the sensor NPN output
    this will block any current flowing out of the sensor and back through the LED in the G540s opto-isolator (LEDs are not very good rectifiers the reverse breakdown voltage is only a few volts )
Name:	proximity sensor to G540 input v2.jpg
    John
    Attached Thumbnails Attached Thumbnails proximity sensor to G540 input v2.jpg
  4. #64
    Sep 2008
    148
    I checked my circuit with a 24VDC power supply and by measuring the Voltage between the Blue and Brown wires I have a voltage of 27VDC. I realize that I need to run a Diode between the Black Sensor Wires and the G540. What I can't figure out is what Size of Diode should I use?
    Any help would be Greatly Appreciated.
  5. #65
    Mar 2007
    2083
    Hi Ronald
    any silicon small signal diode like the 1N4148 would do
    a 1A rectifier diode like the 1N4001 to 1N4007 will be mechanically more robust
    John
    PS
    the 1N4148 has a glass encapsulation and thin wire connections
    https://www.vishay.com/docs/81857/1n4148.pdf
    the 1N4000 series has a larger epoxy encapsulation and thicker wire to carry a 1A current
    https://www.digikey.com/en/datasheet...ivision-1n4001
  6. #66
    Sep 2008
    148
    Quote Originally Posted by john-100 View Post
    Hi Ronald
    John
    PS
    Thanks for the quick response, I had gone out and bought a package of Transistors and Diodes to make sure I had at least a set of each. Ans though there was a reference for the Transistors there wasn't one for the Diodes that you listed in your Diagram. I hope this fixes this issue once and for all as you're the only assistance that I could find on this subject other than generalizations from my usual suppliers including Gecko Drives.
  7. #67
    Mar 2007
    2083
    Hi Ronald
    whats the part number of the diode you have ?
    John
  8. #68
    Sep 2008
    148
    Hi Ronald
    John
    IN4001 is the one I am going to use.
Page 4 of 4 234
  1. Inductive Proximity Sensor electronics problem, help needed.
    By joel0407 in forum CNC Machine Related Electronics
    Last Post: 09-18-2017, 06:17 PM
  2. Proximity sensor wiring
    By Lindzr in forum Automation Technology Products
    Last Post: 08-16-2017, 01:29 AM
  3. Wiring an Inductive Proximity sensor for TB6560. How?
    By Azalin in forum Stepper Motors / Drives
    Last Post: 11-11-2015, 09:19 PM
  4. Help with NPN proximity sensor wiring in parallel
    By bean_086 in forum DIY CNC Router Table Machines
    Last Post: 08-09-2013, 04:44 PM
  5. proximity sensor issue
    By strohkirchw in forum Benchtop Machines
    Last Post: 05-27-2011, 10:14 PM
