587,619 active members*
3,372 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Rigid tapping dwels at bottom with running spindle
Results 1 to 7 of 7
    Sep 2011
    78
    Hi all,
    I have a problem with rigid tapping on a lathe with life tooling and a fanuc Oi-TF controller.
    The machine this occurs on is not very much used even though it is already a year old and supplier customer support is nearly zero.
    When the tap reaches the botom of the hole it dwels there for about a second with the spindle still running before reversing the spindle and retracting in Z. See the attached video at the bottom
    program used is
    G97 S300 M53
    G0 X465 Z10
    M29 S300 M53
    G84 C0 Z-23 R-5 H[360/6] K6 F[300*1.25]
    G80
    have been playing around all day without any succes.
    Tapping without rigid tapping by the way gives the same result : dwelling at bottom of hole with spindle running.
    Feb 2006
    1792
    Re: Rigid tapping dwels at bottom with running spindle
    Why do you have both C and H on the G84 block?
    Why repeating M53?
    Are you sure that rigid tapping is enabled on your machine?
    Sep 2011
    78
    Quote Originally Posted by sinha_nsit View Post
    Why repeating M53?
    Your right c and h do not have to be both in de G84 block
    And the double m53 also isnt nessecery but this shouldnt and doesnt give any problem.
    Riged tapping is a standard option on this machine and it is possible to force some riged tapping related errors to show.
    Also riged tapping is enabled in parameters.
    Does the position page reflect the dwell? It almost looks like backlash.
    You may have a bad parameter setting. I was just at the Fanuc website and downloaded the OiF Function Catalog. Look in the feed section and there is tons related to different ways to feed in rigid tapping. Things like time constants and bell shaped acceleration/deceleration curves and much more. You might want to take a look through your parameter manual and see if something has been changed from factory or you spot a parameter change you think will solve your problem.
    The comment about backlash does not seem completely out of question. Should be able to sort of check that out by grabbing the tool with your handing and seeing if it will give a little.
    Dave
    Dec 2012
    395
    Hey duivenhok,
    What is the brand of your machine ?
    Do you have the correct M & G-code list for the machine, are there example programs in manuals available ?
    Sometimes a non Fanuc code is used for tapping, on our lathes it's different for each brand/machine.
    When nothing works for the moment you can always buy yourself a FAHRION CET-GB floating ER-collet, approx. €110, -
    The FAHRION CET32-GB (ER32-collet) has a bore-diameter from 4.5mm to 12.5mm, always buy the biggest and make adapters for smaller diameters.
    Regards,
    Heavy_Metal.
    can any one give me parameter settings in rigid tapping on cnc lathe p16 oi-td fanuc series? and give me sample program... thanks in advance
  1. Help with Rigid Tapping on Sub-Spindle
    By cjhayes in forum Fanuc
    Last Post: 03-12-2020, 07:33 PM
  2. Rigid Tapping With HSD ES929A Spindle
    By jfred in forum CNC Machining Centers
    Last Post: 10-03-2015, 09:35 PM
  3. Spindle for Drilling/Rigid Tapping
    By dbc1218 in forum DIY CNC Router Table Machines
    Last Post: 02-23-2013, 03:27 AM
  4. Replies: 0
    Last Post: 08-01-2012, 06:39 AM
  5. Rigid Tapping and Spindle Orientation
    By Ben Colby in forum CamSoft Products
    Last Post: 12-14-2010, 03:54 AM
