587,303 active members*
3,587 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > Intro questions - Windows/Kflop/Kanalog and a 17k pound milling machine conversion
Page 2 of 2 12
Results 21 to 36 of 36
  1. #21
    Aug 2007
    138
    Re: Intro questions - Windows/Kflop/Kanalog and a 17k pound milling machine conversio
    LOL....see! you do have it. (kinda scattered, but there!)
    precisely the class of information I was looking for.
    This is going to be no small endeavor. This mill currently monitors a (!@#$!%) of things...right down to current overload for the chip conveyor and lube pump timing.
    Keshka
  2. #22
    Jun 2004
    355
    What I like to do with any new retrofit, is make a spreadsheet that lists all the inputs/outputs needed, along with how they work (i.e. switch to gnd/positive) what voltage they run at.
    Once you have that, you can count up the in/out you need, decide what boards you need, then start mapping in/out to boards.
  3. #23
    Aug 2007
    138
    Tom;
    the VK45 makes use of the RS-485 bus to communicate with three devices Hitachi calls "panel slave". Each panel slave can read limit switches and operate relays. One slave for the control panel. One for the tool changer and the last one to what they call the "distribution board" that has approximately 60 relays and a variety of inputs from buttons and switches.
    If that bus is something usable, it would save me a ton of re-wiring.
    Keshka
  4. #24
    May 2006
    4047
    Hi Dancy,
    You would need to research the protocol. Possibly ModBus? If so, it would most likely be doable. Kanalog has an RS232 port. You would need to obtain an RS232 to RS485 converter.
    TK
    http://dynomotion.com
  5. #25
    Aug 2007
    138
    one can buy RS-485 to ethernet, USB and RS-232 adapters
    RS-485 is the industrial version of serial communications and uses differential signaling so can go much greater distance and much higher immunity to noise.
    Yes it is a version of MODBUS
    and it can be transmitted over ethernet.
  6. #26
    May 2006
    4047
    Hi Dancy,
    You would want the RS232 to RS485 adapter.
    There is a PC program called modpoll that we often recommend using first to verify functionality from the PC and to verify which modbus registers on which device do what you need. Then afterward modify the tables in the KFLOP ModBus C Program to continuously read and write those registers. There are also 2 functions that need to be modified to load and unload the data to/from the registers and KFLOP virtual bits and variables while doing any packing/unpacking/formatting/scaling. In the end you can then for example just set/clear a KFLOP IO Bit and the corresponding relay in the slave will react accordingly.
    TK
  7. #27
    Jun 2004
    355
    Quote Originally Posted by Dancy View Post
    What Tom was suggesting in his previous post, was the devices may not use standard MODBUS.
    It's not unknown for manufacturers to create there own protocol, but still use some form of generic serial communication. The only way to find out, is to either find the official documentation (which may not even give the required details), or to analyse the data and see if it using a common standard, then try and establish how to access all the registers.
    For analysing, try https://www.virtual-serial-port.org/...serialmonitor/
    I've used it in the past for working out why a VFD wouldn't do what the manual said it should, and it has a 14day fully functional demo period.
  8. #28
    Aug 2007
    138
    (grin) ....I have homework to do
    details to follow
  9. #29
    Aug 2007
    138
    Quote Originally Posted by TomKerekes View Post
    Hi Dancy,
    Dang! you have alot of rabbits in that hat! I am having trouble finding all these tidbits that Kflop can do. Have dug into this web page pretty deep and searched the Wiki. I did find a mention of MODBUS. It implies there is a board to attach to KFLOP. Where do I find that? And code at \C Programs\RS232\ModBus\ ?? is this something provided on purchase of the KFLOP? an install disk perhaps?
  10. #30
    Jun 2004
    355
    The KFlop has serial ability as standard, however the pins used don't meet the full RS232 standard. However if you add a Kanalog board, it adds the needed buffer to get full RS232 voltage compliance. RS232 with KFLOP has the details.
    There is also the option to install a driver so you can access the serial port as a COM port on windows, but you shouldn't need to do that - http://dynomotion.com/Help/VirtualComPortwithKFLOP.pdf
    I use a KFlop and Kanalog with Modbus on my lathe to control a Click PLC, and I'll admit it is probably the most challenging bit of KFlop programming I've had to do. It took a few nights of headscratching trying to figure out how to get KFlop to access the right registers, then make the information available for use in the KFlop. Even once I got it working, I still didn't really understand how it worked!
  11. #31
    Aug 2007
    138
    Thanks M_C;
    I have been writing code since 1976 and completely understand! ....if it's working, don't touch it!.
    Have you published your work anywhere? If I may, I would love to see how you accomplished your hardware/software interface to the Click.
  12. #32
    May 2006
    4047
    Hi Dancy,
    Not exactly sure what you mean. But Kanalog connects to KFLOP and converts KFLOP's 3.3V UART signals to proper RS232 levels. So since your system will likely have a Kanalog you can assume there is an RS232 port available. If you ModBus Slaves require RS485 then you will need to add an external 3rd party RS232 to RS485 converter. If you Google "RS232 to RS485 converter" you should find many for only a few dollars.
    You can download our software which includes the ModBus examples from our site.
    TK
  13. #33
    Jun 2004
    355
    Thanks M_C;
    Zip of my lathe files should be attached.
    Essentially the forever loop in Cyclone_init.c (this is my main machine initialisation file which gets run to configure the KFlop), calls the ModbusMaster_Loop() (which exists in ModbusMasterVer1_cyclone.c), which then handles all the Modbus communication.
    That is continually reading two registers and copying them to UserVars in the KFlop for easy access by any C program running - one is the memory location that contains the current turret position (the PLC does the conversion from the grey/parallel encoder and stores the result in a register), the other is one input bank (it contains the lube level, and door status, although I've still never got around to implementing them!)
    And copying the contents of one UserVar to one register - the desired tool position.
    There are also two hardwired inputs/outputs between the Kanalog and PLC, which allow for some basic handshaking and validating. One from Kanalog to PLC goes high to allow a tool change to take place, and the other one from the PLC to Kanalog should be high if the turret is on the desired position and locked. This sequence is handled by the Cyclone_M6/toolchange programs.
    I have just had a scan through my modified ModbusMaster file, and I seem to remember you have to enter register details in 2 or 3 different places. This was the first machine I ever fitted a KFlop to, so the code isn't the tidiest or best commented, and I seem to remember doing that many edits to the Modbus code, I gave up with comments and never got around to adding them.
  14. #34
    Aug 2007
    138
    M_C;
    have had just a few minutes to skim over your code and it looks better than you give yourself credit for. Thank you so much for sharing it with me. I am sure your examples will save me hours of time.
    Tom:
    "board attached" ...my mistake, while reading the snip on modbus in the Wiki. I saw the 3d board model and the two ports looked like a RS-485 board. Woops!
    Seems I read more than one Kanalog can be attached to Kflop. If so, how is that done? If I can't get this monster to talk via their implementation of MODBUS I will have to deal with about 150 in/out items. I have used I/O expanders via the I2C bus
  15. #35
    May 2006
    4047
    Hi Dancy,
    No, only one Kanalog can be connected. However besides Kanalog IO up to 4 additional Konnects can be added for an additional 192 IO (128 inputs and 64 outputs). Note for timing and noise susceptibility reasons ribbon cables should be as short as possible. The demo below is testing under worst case scenario.
    https://youtu.be/gQkyiI_FyTw
    TK
  16. #36
    Aug 2007
    138
    Perfect
Page 2 of 2 12
  1. Morbidelli U13 conversion to Kflop+Kanalog
    By AsErBo in forum Dynomotion/Kflop/Kanalog
    Last Post: 12-23-2019, 08:54 PM
  2. KFLOP/Kanalog set up
    By cjsamples in forum Dynomotion/Kflop/Kanalog
    Last Post: 10-30-2015, 12:58 AM
  3. KFLOP + Kanalog to JF H2N-TD 3Phase 220V Servo Drive Wiring Questions
    By madprinter in forum Dynomotion/Kflop/Kanalog
    Last Post: 06-14-2015, 06:59 PM
  4. KFlop Kanalog and DMM
    By slonold in forum Dynomotion/Kflop/Kanalog
    Last Post: 12-26-2014, 10:54 PM
  5. kflop/kanalog for retrofitting machine with glass scales
    By ihavenofish in forum Dynomotion/Kflop/Kanalog
    Last Post: 03-20-2013, 04:32 AM
