587,645 active members*
3,112 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > G-Code Programing > Starting script needed for home made cnc machine
Results 1 to 8 of 8
    Mar 2015
    3
    Hi folks,
    I've just setup endstops of X and Y. For my Z I use a touch plate. I want to Home Z using the touch-plate (3.9mm thick) first, then I want it to home X Y before starting the job.
    One thing needs to be noted is that my Y homes 142mm past the start of
    my work area. So I can set an offset on my Y with something like M206 Y-142??? I think.
    This is what I have now but I'm very unsure if this will work as I want it to.
    ;Project <project>
    ;Created by Estlcam version <version> build <build>
    ;Machining time about <time> hours
    G28 X Y
    G1 Y150 F600
    M0 INSTALL TOUCH-PLATE
    G28 Z (Home Z to touchplate)
    G1 Z10 F120
    M17 (Enable Steppers)
    M0 REMOVE TOUCH-PLATE
    G1 Z-3.9 F120
    G92 X0 Y0 Z0
    G1 Z4 F120
    G28 X Y
    G90
    Thanks in advance,
    John
    Jan 2005
    15362
    Re: Starting script needed for home made cnc machine
    Quote Originally Posted by solly747 View Post
    Hi folks,
    ;Project <project>
    G28 X Y
    G1 Y150 F600
    G1 Z10 F120
    G1 Z-3.9 F120
    G92 X0 Y0 Z0
    G1 Z4 F120
    G28 X Y
    G90
    Thanks in advance,
    John
    Z is never homed to a touch -plate machine Home is Z axes up to it's max travel or where ever you want it to stop by activating the Home/ limit switch
    Z axes offset and Touch-Plate is used for setting Tool length offset G43 Etc Tool offsets G43
    Work Offsets us G54 Etc
    G28 try G53 or just G0
    G92 X0 Y0 Z0 never do a Z axes move on the same line as a X and Y axes move Z axes move is always done before a X Y move
    Mactec54
    Jan 2005
    15362
    This is how Z axes Tool offset works
    Mactec54
    Mar 2015
    3
    Thanks for all this.
    Are you able to change what I have to what you recommend as a whole script? G53 is not supported by Marlin (sorry I should've said that's what I was using).
    Still trying to get my head around it all.
    Thanks again for the reply
    Jan 2005
    15362
    No I can't help you with your control, you are best to try where the Marlin software is used there may be some users on here, but in general that is what is happening when people get into a system with very little support
    Mactec54
    Jan 2005
    15362
    This thread most likely has a better system than what you are working with https://www.cnczone.com/forums/uncat...cam-forum.html
    Mactec54
    Mar 2015
    3
    Thanks mate
    Feb 2009
    6028
    Marlin is great for 3d printers, but not what you want on a CNC. Your way better off going with GRBL or Linux CNC or one of the other open source packages for CNC.
  1. Home made machine vibration
    By vakeiros in forum DIY CNC Router Table Machines
    Last Post: 04-10-2017, 03:18 PM
  2. Home Machine before starting program
    By bensmed91 in forum Fanuc
    Last Post: 01-28-2016, 01:37 AM
  3. Home Made Injection Machine
    By Rob_M. in forum Moldmaking
    Last Post: 11-12-2012, 02:47 AM
  4. accuracy of home made CNC machine
    By spaltiel in forum DIY CNC Router Table Machines
    Last Post: 04-01-2010, 09:50 PM
  5. Home made encapsulating machine?
    By tybrenis in forum Community Club House
    Last Post: 01-15-2007, 11:04 PM
