587,158 active members*
3,076 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Can’t get the right surface
Page 2 of 2 12
Results 21 to 24 of 24
  1. #21
    May 2013
    701
    Re: Can’t get the right surface
    Would this be acceptable? Its not the same shape but it looks good to me
  2. #22
    Apr 2018
    15
    Quote Originally Posted by RAF. View Post
    Yes that worked much better thank you. Was able to connect two lines so I was able to make 4 chains.
    Took me a bit to get the rest. I made a solid but when I removed the middle it deleted my walls on the inside as well. So I used planar for the top and bottom and I was able to keep the internal walls. Now just to figure out how to give the tune wall to top of the flat flange a radius and I can get started.
  3. #23
    May 2013
    701
    Quote Originally Posted by boosted67 View Post
    Using the Cross Section as Burrman suggests works very good as well and is easier you may want to try it as well. What ever works is good
    Some Cross Section Pics
    RAF
  4. #24
    Apr 2018
    15
    RAF
    Exactly whatever works. First time I was able to get this function to work but worked much better.
    Something odd happens with the tool path I’ve never seen. I send the mill down the center of the oval and it stops about half way. I figured once it got to the part of the drawing that was negative it was stopping on its own and I needed to write for the other side. But when I rough in the Z it seems to be running do to my surface, but then it cuts another .250 on another pass for some reason. I’ve tried everything I can think of. Makes no sense.
Page 2 of 2 12
  1. Replies: 0
    Last Post: 04-20-2015, 10:09 PM
  2. 3D Surface Toolpath milling deeper than surface
    By moto1965 in forum Mastercam
    Last Post: 07-30-2014, 04:15 PM
  3. Surface over a surface problem
    By omnitech in forum FeatureCAM CAD/CAM
    Last Post: 10-20-2011, 03:42 PM
  4. Fillet surface to surface problem
    By vincent13 in forum Mastercam
    Last Post: 02-10-2011, 01:15 PM
  5. Surface to Surface Filleting and Trimming
    By cowpoke in forum Mastercam
    Last Post: 03-17-2009, 02:42 PM
