587,482 active members*
3,082 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Tapping program question
Results 1 to 5 of 5
    Apr 2015
    26
    Regarding a 1993 Fadal VMC3016 with rigid tapping:
    If I have an M1 after tapping a hole to a particular depth (To blow out chips/oil), can I program to go back in a second time (deeper) and expect the machine to stay synchronized with the thread it just cut previously?
    Aug 2007
    3
    Re: Tapping program question
    The 3 Fadals I have had would retap a hole perfectly as long as I didn't change tools. Best rigid tapping machine I have.
    All my other CNCs (Matsuura, Kitamura, Haas) would open up the thread and the no-go gage would go if I programmed a second cycle on a previously tapped hole with a deeper Z depth.
    Apr 2015
    26
    Thanks, Larry - interesting about the Fadal being more precise than the others.
    I didn't get an answer here soon enough, so I just went ahead and experimented. Found some peck tapping programs online, combined some ideas from different ones, and made my own changes I found to be necessary. Works great. I squirt cutting oil in the hole with a syringe from the bottom up until its full, then tap to Z-.600; M1 to blow out chips with a tube into the bottom of the hole (Z waiting at +.300) and fill the hole with oil again; "Start" and tap to Z-.850; M1 again to blow out chips and fill the next hole with oil; Etc. I found I had to add the spindle speed after every M45 and second Z depth for the program to work right - was all funky before I did that. Here's what I ended up with:
    N1 G17 G20 G40 G49 G80
    N2 T04 M06 (1/4-28 spiral point tap)
    N3 G00 G90 G54 X__ Y__
    N4 S1000 M5
    N5 G43 H04 Z.3
    N6 G84.1 G99 R0+.3 Z-.600 S1000.2 F35.714 (Rigid tap)
    N7 M01
    N8 M45 Z-.850 S1000.2
    N9 M01
    N10 G80 X__
    N11 G84.1 G99 R0+.3 Z-.600 S1000.2 F35.714
    N12 M01
    N13 M45 Z-.850 S1000.2
    N14 M01
    N15 G80 X__
    N16 G84.1 G99 R0+.3 Z-.600 S1000.2 F35.714
    N17 M01
    N18 M45 Z-.850 S1000.2
    N19 M01
    N20 G80 X__
    N21 G84.1 G99 R0+.3 Z-.600 S1000.2 F35.714
    N22 M01
    N23 M45 Z-.850 S1000.2
    N24 M01
    Etc., X 10 holes, in my case
    Mark
    Mar 2008
    683
    I'm too paranoid to use rigid peck tapping on my fadals. Broke a tap in very expensive part so i don't do that anymore. But good to hear about Larry's results.
    Feb 2007
    171
    Warrenb, setting up and testing your RT is quite easy. You only need a rigid tapping test tool (SVT-0077- $75 in stock), put in a collet holder and run a short rigid tapping program while you have an indicator in the threads watching for deviation. You should be able to adjust Gain and Ramp in the parameters until you get it tight as you need. We have a video on our web site showing how to do this. I also have a test Rigid tapping program I can send you for the test and adjustment.
    Let me know how or if I can help.
    FadalCNC Support
  1. CNC FADAL TAPPING PROGRAM
    By jhamhez2526 in forum Fadal
    Last Post: 07-05-2017, 06:28 AM
  2. Replies: 18
    Last Post: 02-16-2016, 11:53 AM
  3. writing g-code program for fadal vmc for tapping and drilling
    By mrivera85706 in forum G-Code Programing
    Last Post: 08-31-2011, 11:23 PM
  4. Tapping program on a Takumi Seiki
    By artin5 in forum G-Code Programing
    Last Post: 08-29-2010, 09:11 PM
  5. Lathe Tapping Program
    By stoddgopats in forum G-Code Programing
    Last Post: 10-06-2008, 08:29 PM
