Hi Guys/ (gals?)
I have been putting off the inevitable control retrofit for my 3 axis vertical mill with Anilam GXM control for too long now.
Recently the machine started acting up again. I re-soldered a lot of the boards etc, but this afternoon it just ran off in Z without warning, wrecking an expensive carbide cutter and my tool setter.
Long and short is that I just do not trust the control any more.
I would like to retrofit the control and also replace the old dc servo's (4.5Nm cont. stall torque) and drives. (these still use encoder and tacho feedback and whine like a ringing ear)
I do sometimes make money with the machine in my spare time, but would like to keep investment in the old iron realistic.
Based on info provided, would anyone care to suggest a control/ pc based control and servo option?
Something with post processor support for Fusion or other Cam packages would be a big plus.
Also worth mentioning is that I have a old nikken 4th/5th axis that I drive from two nikken alpha controllers for indexing only. If I can incorporate these into the new control it would certainly be a big plus also. Nikkens are currently also fitted with DC servos, but I can retrofit to AC servo's if required.
Any suggestions or warnings welcome.
P
