587,529 active members*
3,286 visitors online*
Results 1 to 7 of 7
    Mar 2007
    67
    CNC mill vs. CNC router
    I've been using a benchtop CNC mill (R8 taper) for a number of years as a hobby. The vast majority of my operations are profile cuts, pockets, and hole drilling in aluminum that's, at most, .25" thick, and MDF that's, at most, .5" thick. I never need more than .005" accuracy, which the mill easily provides. The machine offers 14" of X travel, 6" of Y, and 9" of Z. I use a number of software tools for design, but they all end up outputting G code which I run in Mach 3 to drive the machine.
    I'm often constrained by the mill's work envelope and find myself increasingly thinking about replacing the mill with a CNC router, which would give me a significant increase in Y travel within the same footprint as the mill. It would also process MDF much faster. I don't know much about these routers, though, so I thought I'd come here to gather some pros and cons. Would it be able to do all the things I mentioned I currently do with my mill? If I ever wanted to work on steel, would I be able to (I assume I'd have to add a coolant system, but Fog Buster seems like it would be well-suited to one of these things)? Any other considerations? Thanks for any tips.
    35538
    Re: CNC mill vs. CNC router
    Routers come in all shapes and sizes, from flimsy hobby level machines to heavy industrial machines. Without knowing exactly what you are comparing, it's hard to answer.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    May 2005
    1662
    Is owning a mill and a router an option ?
    Anyone who says "It only goes together one way" has no imagination.
    Apr 2004
    5749
    Forget about milling steel with a router, even a heavy-duty one will have the wrong kind of spindle. But if a router is rigid enough, it should be able to handle aluminum. And it will do a better job on MDF than a mill, or at least do it faster with less dust (assuming it comes with a dust collector). Like Cyclestart implies, it's better to have both, if possible; they do different things. .
    Andrew Werby
    Website
    Jan 2005
    1943
    Quote Originally Posted by awerby View Post
    You can of course have different spindles that you can mount on the Z-axis. One for wood and non-ferrous and one for steel.
    May 2015
    1422
    Still for hobby work, Involute?
    I bought an OmioCNC 6040 machine (the X2200L) a few years ago, about 22" x 14" x 5.5" work envelope. I upgraded the controller (from USB to ethernet) and the deck (from bendy extrusion to solid plate) and added a $20 dual nozzle air carried mister rig. Including the bench/enclosure I made for it and tooling it ran up a total of maybe USD4000.
    I still use the little SEIG X2 mill for steel. The Omio will work steel and even stainless but it's slow going, hard on the tooling and machine and you can hear it being unhappy about the whole thing.
    Having both is a nice combination.
    Feb 2019
    11
    I think it is really up to your use of a mill or router, but there are not enough info for me to judge on that.
    If you go with a router, Thermwood has pretty good price/quality ratio routers for both MDF and aluminum, but of course steel is a different matter.
  1. My first router/mill
    By Jakob in forum CNC Wood Router Project Log
    Last Post: 11-03-2018, 01:03 PM
  2. Our first cnc router (or a mill if you say)
    By mitis in forum Uncategorised MetalWorking Machines
    Last Post: 09-27-2014, 07:04 PM
  3. CNC Mill or CNC Router?
    By spacifique1 in forum Australia, New Zealand Club House
    Last Post: 03-16-2007, 05:59 AM
  4. Router or Mill?
    By UKRobotics in forum Uncategorised MetalWorking Machines
    Last Post: 04-04-2004, 06:45 AM
