Iam building a CNC based on openbuilds design. I have 4 wantai 57BYGH633 motors with DQ542MA drivers.
The CNC will have 1000mm x 500mm with two motors on Y. Belt driven and leaded Z.
I have so many questions... Can you help me with some of them?
1- I though that six wire motors has to be connected without the center tap (taped off). But researching i´ve seen that many configurations ar available. Half-coil hookup, full coil, etc.
Wich are the pros and cons? I will use the CNC for milling. Recomendations?
2- Drivers configuration related to current. Do I need to limit the current? Iam totally lost here...
3- Power supply. Switching power supply 24v? The motors say 3A, 15A is enought?
4- Anyone have a wiring diagram of this stuff? I will connect this to mach3
5- The PC needs some special requeriments about clock speed or something like that?
Thanks!!!
