Re: How do I setup a 2.2kw spindle so iy could be indexed and held in that position?
Originally Posted by
allaces
Using an auxiliary stepper motor to do the indexing was something I considered before reading your post, but I thought that might be ANOTHER one of my bad ideas. Now that you basically confirmed that this would be a reasonable option...
I was thinking of using a 12VDC automotive air conditioner mag clutch for engaging/disengaging the stepper.
What do you think?
Ray
I am considering doing the same thing on my lathe using a DMM 1.8KW servo, and a 12V automotive air conditioner clutch. The air conditioner clutch will transmit about 10 HP so should work well for a NEMA 34 stepper.
My lathe is a bit larger than yours (10 HP spindle), hence the need for a larger indexing drive.
mactec54
Well lots of machining centers are using a regular Ac motor driven with a VFD Drive and have no trouble with indexing, I have built them also with indexing using a regular VFD Drive, so it can be done but not with the spindle motor he wanted to use
I have not been successful trying to index my spindle motor with a sensorless vector VFD, maybe you could give me a hint as to how to accomplish it.
Motor: Fanuc 7.5 KW, 6000 RPM, 4 pole
VFD: Automation Direct GS3, 10 HP w/encoder input option
Encoder: 1024 line, RS422 output, driven from the spindle
Control: Galil DMC-1846
Speed control works perfectly, but have never been able to get it to index. The original Fanuc drive would index it to +/- 1 degree.
Jim Dawson
Sandy, Oregon, USA
