587,155 active members*
5,172 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Help Drawing Guitar neck
Results 1 to 7 of 7
    Dec 2016
    9
    Hey everyone,
    I'm having some trouble with a guitar neck drawing. I've attached 2 images to help illustrate what I'm working on. The area I need help with is where the cylinder section meets the headstock. I need to blend these two sections together in a pleasing way.
    I've tried surface to surface fillet and solid fillet, but both of these fail. What strategy would you guys try?
    BTW, I'm using V29 mill standard
    Thanks!
    Bob
    Dec 2008
    4548
    Re: Help Drawing Guitar neck
    I would have a full cylinder. the headstock shape would be a block extruded fully out in both directions.
    Boolean the cyl and headstock pieces. Then fillet the connecton, then cut the flats back into it.
    May 2013
    701
    Quote Originally Posted by soxfan963 View Post
    Hey everyone,
    Thanks!
    Bob
    The way I did this using SKIN a little work though I put the PRS angle 7 deg. not sure what Paul uses for angle.
    Had to use some work plane surfaces to get the geom correct but is doable with good old BOB.
    BurrMan may have a simpler way he's very good at this stuff.
    Good Luck
    RAF
    Apr 2009
    3376
    Search the Forums,been many threads on this forum and others
    May 2013
    701
    [QUOTE=soxfan963;2255408]Hey everyone,
    Thanks!
    Bob[/QUOT
    Might try Revolve a donut at the transition point and then subtract. Some of my Guitars have something like that but I prefer the skin method
    RAF
    May 2013
    701
    [QUOTE=RAF.;2255684]
    Hey everyone,
    Thanks!
    Bob[/QUOT
    RAF
    Skin work picures
    Dec 2008
    4548
    [QUOTE=RAF.;2256056]
    Quote Originally Posted by RAF. View Post
    Skin work picures
    I would suggest this as the best way in BobCad. It has limited blending options.
    Although patchwork is a more advanced method, it is the best way in BobCad.
