587,892 active members*
4,365 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Taig Mills / Lathes > Taig 3000 DSLS Mach3 Setup and XML file request
Results 1 to 15 of 15
    Jan 2017
    Hey guys, I just bought a Taig Micromill 3000 DSLS with Mach3. My fantastic friend misplaced his microproto CD that included the setup files to run the machine. Do any of you guys have the files available? I'm looking for the following files...
    Mach3mill.xml
    MPS1024E.set
    I tried contacting Microproto directly at [email protected] for the files and the email apparently doesn't exist. It would be a huge help! I have everything ready to go and I just need these files for Mach3.
    Apr 2005
    149
    Re: Taig 3000 DSLS Mach3 Setup and XML file request
    Sure.... drop me a PM with your e-mail and I'll send them to you.
    To make the .XML trouble free for you.... I need to know.
    1. 3 Axis or 4 Axis?
    2. Are you going to work in inches or MM
    Of course, you can set any of this up... but this way it will be basically plug & Play for you. Dan.
    Is it possible to get this info still?
    Quote Originally Posted by Ican View Post
    I would really appreciate this same information. I can't get this thing running to save my life.
    Apr 2004
    5752
    Travis - did you buy your Taig mill new or used? Taig tech support is pretty good, if you're using their system to run it - have you called them for help?
    Andrew Werby
    Website
    Apr 2005
    149
    Quote Originally Posted by Traviss396 View Post
    Is this a stock Taig mill?? Let me know some specifics and I am happy to help. Thanks. Dan.
    Dec 2018
    36
    Hi ican i am in need of Mps2000 v2.2 would you happen to have it? Thank you kindly happy holidays
    The machine is a microproto 3000 DSLS
    It is 4 axis
    I will work in mm
    Apr 2005
    149
    Quote Originally Posted by anilchawla View Post
    It is 4 axis
    I will work in mm
    PM sent.
    Oct 2006
    2
    Sorry to necro an old thread but I wonder if you could send me a copy of that XML also @Ican? Same spec actually: Microproto 3000 DSLS, 4 axis, primarily will work with metric measurements.
    I have not used my machine for a few years and when I removed the dust sheet from it today to start it up again the computer that used to run it has failed so I need to set up afresh and it would be great to have the XML as a sanity check.
    Much appreciated if you still have the file conveniently to hand.
    Sep 2020
    2
    Ican,
    Would it be possible for you to send those files to me, please? I am helping a friend get his going (someone gave it to him without the disk).
    1) He has and wants to use the 4th Axis at some point.
    2) He will likely use inches.
    Sep 2020
    2
    Quote Originally Posted by Masock View Post
    Ican,
    Nevermind. I finally was able to get with someone from Microproto.
    Apr 2005
    149
    Sorry, I have been on the road.
    Jul 2015
    2
    Sorry to kick start an old thread but I have just inherited a Taig Micromill 3000 DSLS but without the disk of files and info that goes with it.
    Is it a possibility to get a copy of those files as well?
    Mine is a 4 axis and I will be working in MM.
    Thanks in advance.
    Apr 2004
    5752
    You''ll need to buy a seat of Mach3 or 4 to make it run; this isn't free software: https://www.machsupport.com/ Once you've got that installed, all you need is the XML file specific to your machine. Taig will be able to supply that.
    Andrew Werby
    Website
  1. Considering Taig DSLS 3000 CNC Mill Purchase.
    By Crashbox in forum Taig Mills / Lathes
    Last Post: 12-25-2014, 06:14 AM
  2. Taig DSLS 3000 Question
    By GregGleason in forum Taig Mills / Lathes
    Last Post: 05-11-2014, 04:27 PM
  3. TAIG 3000 DSLS
    By SHMUEL in forum Taig Mills / Lathes
    Last Post: 09-27-2010, 03:47 PM
  4. Taig DSLS 3000 vs. Super (Sieg) X3 CNC
    By msc in forum Taig Mills / Lathes
    Last Post: 04-19-2007, 10:08 PM
