587,794 active members*
3,543 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > Mori Seiki CV500 - How to write/change parameters? MSC-803 controller.
Results 1 to 19 of 19
    Mar 2018
    6
    Hi everyone,
    I have a Mori Seiki CV 500 mill with pallet changer and automatic tool changer (25 tool holders)
    I recently disconnected the cables for the motor turning the tool magazine and switched the power back on.
    After this I get an alarm about lost Zero Point of the Magazine.
    So now I have connected the cables back to the motor, and I try to follow a procedure on how to do the adjustment/calibration of the zero point.
    I understand mostly of the procedure, but there is one step I have problems with.
    I need to change a parameter in the PLC, but I am not able to set the new parameter.
    I have logged in to the correct menu, and found the parameter I was looking for (#6440) and I need to set bit 2 = 1
    But It does not get stored after I set it?
    I have tried to do this in MDI mode, no difference.
    I have tried to switch off all Write Protection, no difference.
    I have tried to restart the controller after the change, no difference.
    I have tried to switch the main power of the machine off and on after the change, no difference.
    So, if anyone could help me out with this it would be of great help.
    As I can understand from the procedure I need to change this parameter, so I can use the Handle (manual pulse generator) to turn the magazine during the calibration.
    Best regards,
    Kjetil from Norway
    Sep 2017
    139
    Re: Mori Seiki CV500 - How to write/change parameters? MSC-803 controller.
    Hi Kjetil
    The controller is M50MM or M64 ?
    Mar 2018
    6
    The controller is Meldas 64 from Mitsubishi
    Br,
    Kjetil
    Mar 2018
    6
    I actually spoke to DMG mori support phone for a few hours ago, and they sent me the full procedure on how to perform Zero Return Calibration on the Magazine axis.
    It says I need to go into Field Adjustment Mode before I can change this parameter.
    To get to the Field Adjustmen Mode I should hold SPINDLE STOP and FEED HOLD button for a few seconds, and then the FEED HOLD light diode will start blinking.
    But I have tried this now several times the last hour, and it will not go into Field Adjustment Mode. The diode is not blinking.
    Dec 2011
    18
    hi kmokkelg i have a problem too with my mori seiki control msc 803 its a lathe and i need to adjust z axis zero point but it has interlock i have no info about that would you please share with me your procedure to readjusting zrn return?thanks in advance
    Mar 2018
    6
    Hi Sengoku,
    I managed to get the mori into field adjustment mode, by spindle stop and feed hold.
    I just had to hit them many times randomly and together, and then it worked.
    If you send me your email address I can send you the procedure I got from Mori Seiki (it is also attached here)
    Quote Originally Posted by sengoku View Post
    Feb 2005
    69
    I doubt the magazine procedure will work for setting the z-axis. I have attached one for a CL series lathe with MSC-803 control. I might have a better copy but this should work.
    Feb 2005
    69
    What is the Mori lathe model you need the zero return procedure for z-axis?
    Dec 2011
    18
    hi thanks for reply i have mori seiki cl-150 lathe
    Aug 2018
    7
    I have this problem too, would you please say that what
    can I do to move axis forsetting?
    Jun 2007
    9
    Hi All,
    I am having hard time putting my CV500A into service , as all the manuals were lost during shipping.
    Can any one provide me the operation and maintenance manuals?
    May 2020
    1
    Hello everyone,
    I'm looking for an alarm removal procedure
    Z71 AUX DETEC. ERR 0001
    The machine is CV 500 -471
    MSC-803 system
    Thanks in advance to everyone.
    Valentin Petrov
    valiosl
    Feb 2010
    9
    I have a CV500 with MSC803 control. The machine has been out of service for 3 years. We've got it back up and running. The issue we have is that we cannot edit any programs. In GOP screen, when we go to unlock the Program key, the control says to put a password into parameter - parameter 58 has five blank entries.
    We never had any password in play for the last 17 years - this is a new problem.
    Any thoughts?
    We've tried all the easy number combinations, only response is "Wrong Password"
    Mar 2016
    11
    Jayeff1 contact for me, my support you unlock GOP
    Check messege
    Feb 2010
    9
    mr_tetua,
    we discovered the code to unlock program parameter - the code we used had to be put into #59 which unlocked the program edit function - it was an eight digit code.
    We are back in service, fully functioning.
    Thank-you
    Feb 2021
    2
    Quote Originally Posted by kmokkelg View Post
    Hi everyone,
    Best regards,
    Kjetil from Norway
    Hello Kjetil,
    Need your help.
    I have the same problem as you had. How did you resolve it?
    Best Regards
    Sergej
    Feb 2010
    9
    Hi Kjetil,
    On our CV500, we have to change #6440, bit 3 to be able to use MPG for tool chain alignment.
    Attachment 458740
    Attachment 458742
    I'm not sure these images will post properly - images are from cv500 tool magazine alignment document.
    JayEff
    May 2015
    3
    Quote Originally Posted by navinbhas View Post
    Hi Kjetil
    MSX-803III the i don't get the diagnostics page. is there a different method for this also aux axis APC reference loss. So please help.
    Thank you ????
  1. MF-T6 Controller on Mori Seiki parameters
    By adventuremetal in forum Fanuc
    Last Post: 07-18-2017, 04:27 AM
  2. Mori Seiki GV-503 Parameters HELP Please
    By GokhanGul in forum Mori Seiki Mills
    Last Post: 07-24-2014, 11:29 PM
  3. with PMC parameters for Mori Seiki CL-20A
    By zoik4you in forum Fanuc
    Last Post: 08-10-2013, 03:39 PM
