587,614 active members*
3,824 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Issues with using tool length Utility
Results 1 to 5 of 5
    Feb 2014
    197
    I am having an issue with setting tool length table while using the Utility. I'm thinking it is some sort of glitch....? I can run the utility for the first tool but on the second tool, after I jog to my locate point, then hit MANUAL, the controller goes to the MDI screen. I have to start the Utility over starting with the second tool....because it's offset was not collected. Also, it looks like it is loading the previous file I ran vs continuing the Utility.
    Suggestions?
    Apr 2014
    345
    Re: Issues with using tool length Utility
    When you start do you put too 1 to tool 10 or whichever?
    Feb 2014
    197
    Yes. It gets halfway through the second tool and goes to the MDI page. It stops at the same location each cycle through the utility. I jog to my gauge block, hit the MANUAL button and then it goes to the MDI page.
    Apr 2014
    345
    Strange I don’t really have an answer you could try the classic reseat all the cards and the zero memory procedure but I have no clue if that will help you out.
    Feb 2014
    197
    I will do some more digging before I go there. Thank you though.
  1. Tool length offset table in combination with undefined tool
    By extrapilot in forum Mach Software (ArtSoft software)
    Last Post: 09-01-2018, 01:33 PM
  2. Replies: 6
    Last Post: 06-27-2015, 10:04 PM
  3. Replies: 7
    Last Post: 01-23-2013, 05:46 PM
  4. Tool Setting Utility Problem
    By impexio in forum Fadal
    Last Post: 01-21-2012, 06:37 PM
  5. Tool length offset issues
    By Danno in forum Mach Mill
    Last Post: 01-11-2010, 11:42 PM
