587,611 active members*
3,824 visitors online*
Results 1 to 10 of 10
    Jun 2010
    Parameters Leadwell MCV-0
    Hi
    I deleted all parameters.
    My machine: Leadwell MCV-0 FANUC OM
    Please help!!
    May 2009
    181
    do you have another one (machine)?
    did you check for a list in the back of the machine?
    did you call leadwell yet?
    Dec 2003
    24220
    You also need the 900 option parameters, the diagnostic/counter/timers and any 9000 macro programs.
    Al.
    Albert E.
    Feb 2007
    9
    hi,i have a Option Parameters, NC Parameters & Pc Parameters fanuc OM-A MCV-OP leadwell machining centre you need fanuc OM-A.plese send e-mail ([email protected]
    Jan 2009
    6
    Leadwell MCV 0
    Hi we have all parameter of that machine if you required then plz mail me at [email protected]
    Another thing if i want to run the machine in dnc mode then,have any bit or M code for the same?
    And also we have not manual of that machine can you provide manual?
    Oct 2013
    2
    We have a 1995 Leadwell MCV-OP L2SIE0323, Fanuc OM. We're replacing the memory board and need the parameters for this. Do you have parameters for this model?
    Sep 2018
    4
    [QUOTE=MARCINZUR;790755]Hi
    Please help!
    Pls send me parameters Leedwell MCV O FANUC OM
    [email protected]
    Jul 2015
    20
    Quote Originally Posted by MachII View Post
    You have The OE1 AND OE2 eprom files în hex format?.I change The controller for my MCV with 0MF and i need change The memory on Mainboard.
    Pls sens an email [email protected]
    Oct 2018
    2
    Re: Parameters Leadwell MCV-0
    Did anyone get the parameters for this? I need them for leadwell mcv 1000bp with fanuc omf control, I have everything working except the tool change, can do most tool change movements in mdi via g and m code but program just stops after g28 z0, maybe a diognostic or timer parameter, in manual mode I get a 1046 then 530 alarm when trying to get to g30 2nd z 0. Thanks
    Apr 2022
    11
    Hartford VMC-1020
    SYSTEM:0M
    PMC OE1/2 CHIP LOST
    I have a Hartford VMC-1020 with Fanuc O-MD system, but the PMC ladder diagram is lost.
    Could you please send me an OE1/OE2 file OR Picture? Thank you very much!
    Email:
    [email protected]
  1. Leadwell 550D parameters.
    By Mikey69 in forum Fanuc
    Last Post: 10-12-2013, 02:21 AM
  2. Leadwell MCV-OP Parameters
    By MachII in forum Fanuc
    Last Post: 10-11-2013, 07:21 PM
  3. Parameters Leadwell MCV-OP
    By zavateandu in forum Fanuc
    Last Post: 01-24-2013, 08:46 AM
  4. Leadwell local parameters
    By Dick1951 in forum Uncategorised MetalWorking Machines
    Last Post: 02-17-2011, 09:32 PM
  5. Aide- moi SVP. Leadwell parameters
    By Mikey69 in forum French
    Last Post: 06-04-2009, 09:35 PM
