587,115 active members*
2,826 visitors online*
Results 1 to 5 of 5
    May 2003
    323
    Coolant color
    Why coolant in my lathe turned pink color.
    Should I be worried?
    Sent from my MHA-L29 using Tapatalk
    Re: Coolant color
    Did someone use Dykem to troubleshoot a part? I have noticed that if its not given a chance to dry all the way, or if a lot is used at once. It tends to dye the coolant.
    May 2003
    323
    Re: Coolant color
    Quote Originally Posted by aroundtuit View Post
    No.
    Apr 2012
    90
    Re: Coolant color
    What material are you cutting? Brass tends to turn my coolant a light shade of blue for whatever reason.
    May 2003
    323
    Re: Coolant color
    Quote Originally Posted by AARONT View Post
    Steel, Aluminum, Inconell
  1. Coolant clean out and improve coolant return.
    By Djstorm100 in forum Tormach Personal CNC Mill
    Last Post: 07-17-2018, 04:49 AM
  2. Replies: 8
    Last Post: 08-09-2016, 04:55 AM
  3. Replies: 0
    Last Post: 12-26-2013, 04:26 PM
  4. Fox gets some color
    By cncadmin in forum EnRoute
    Last Post: 04-20-2012, 03:10 AM
  5. COLOR!
    Last Post: 01-03-2012, 08:50 PM
