587,481 active members*
3,017 visitors online*
Results 1 to 5 of 5
    Sep 2007
    37
    SIEMENS 828D CYCLE83 DEEP HOLE PECK DRILLING CYCLE
    Hi
    I am having trouble understanding this deep hole peck drilling , when i post this from hsmworks everything seems fine , but when i run the program, the drill doesnt seem to fully retract it just runs like a chip breaking cycle , which obviously now builds up with chips a sample of the code is attached Attachment 292372 any help on this would be greatly appreciated to all you siemens gurus out there!!
    Jul 2013
    9
    Re: SIEMENS 828D CYCLE83 DEEP HOLE PECK DRILLING CYCLE
    Hello,
    The issue you are having is because the 12th parameter in the cycle needs to be set to 1 not 0.
    CYCLE83(83.807,0,2,-65.391, ,-1, ,0, , ,1,0, ,1,0,0,0) yours
    CYCLE83(83.807,0,2,-65.391, ,-1, ,0, , ,1,1, ,1,0,0,0) mine
    If you can change that parameter you should see a full retract from the hole.
    Sep 2007
    37
    Thanks Mate , will give it a go, much appreciate it
    Sep 2007
    37
    IT WORKED , THANKS HEAPS MATE!!:cheers:
    Jul 2018
    12
    Sinumerik CYCLE 83 used for deep hole drilling . We also known as deep hole peck drilling cycle
    CYCLE83 (RTP, RFP, SDIS, DP, DPR, FDEP, FDPR, DAM, DTB, DTS, FRF,
    VARI, _AXN, _MDEP, _VRT, _DTD, _DIS1)
    Where, RTP- Retraction plane (absolute)
    RFP- Reference plane (absolute)
    SDIS- Safety distance
    DP- Final drilling depth (absolute)
    DPR- Final drilling depth related to reference plane .
    FDEP- First drilling depth (absolute)
    FDPR- First drilling depth relative to reference plane
    DAM- Amount of degression
    DTB- Dwell time at final
    DTS- Dwell time at starting point for swarf removal
    FRF- First drilling depth feed rate factor . Range value
    0.001.....1
    VARI- Machining type : (chip break =0 , swarf removal= 1)
    for more details my link is - http://www.hdknowledge.com/2018/09/h...ing-cycle.html
  1. peck drilling cycle
    By vance1911 in forum Okuma
    Last Post: 10-31-2013, 04:54 AM
  2. Combining peck drilling cycle with deep hole peck
    By adams4182 in forum G-Code Programing
    Last Post: 07-28-2013, 09:07 PM
  3. Hole Machining - Deep Drilling Cycle in Sprutcam
    By kfwittekiend in forum SprutCAM
    Last Post: 11-19-2012, 01:04 PM
  4. siemens 840D post deep hole drilling
    By meadowtech in forum FeatureCAM CAD/CAM
    Last Post: 03-02-2011, 01:09 AM
  5. peck drilling cycle
    By saravananraju76 in forum Hyundai Kia
    Last Post: 11-26-2009, 02:11 AM
