587,380 active members*
3,006 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas vce problem only one axis in position
Results 1 to 3 of 3
    Apr 2011
    112
    Hi guy i recently got a used hass vce from 94 and my position meniu it showing only Y axis and olso it says safety delay When i try to referance the machine. Any one hâd this problem?
    https://youtu.be/RvvibhNV2x0
    First is there a red alarm for your y access up on the control panel. Is the y-axis not running at all working. And are you using a servo you probably have serveral amplifiers in the back in electrical cabinet your Y access should be a 30 Amplifier do not switch the power cords you will ruin your amplifier take the tool holder communication access cord and hook it up to your y access amplifier that will tell you if the amplifier is bad and if you have a tester he can test diodes but if you know how to test continuity dials are pretty much useless
    Apr 2011
    112
    Re: Haas vce problem only one axis in position
    it dont move any axis. Its anormal to have only Y axis in position meniu . Inside of the cabinet there are 4 drive . If there was a drive fault it mst have a alarm on diagnostics but it says NO alarm . There is any way axis XZ be disabled from parameters ?
  1. Haas TL-1 Work Offset Position Display Problem
    By CENTURION in forum Haas Lathes
    Last Post: 05-27-2016, 08:12 AM
  2. Haas VF-5/50 X axis overload problem
    By CNC314 in forum Haas Mills
    Last Post: 05-28-2015, 04:52 PM
  3. HAAS 4TH AXIS POSITION MACRO 09817 NEED HELP
    By heavenlykid in forum Haas Mills
    Last Post: 05-13-2015, 07:36 PM
  4. haas 4th axis problem
    By mattfurches in forum Haas Mills
    Last Post: 05-08-2012, 06:08 PM
  5. Z Axis home position problem Arrow 500
    By BSavulis in forum Cincinnati CNC
    Last Post: 03-09-2011, 04:39 PM
