587,771 active members*
2,948 visitors online*
Thread: THE GRIZZ
Page 31 of 37 212930313233
Results 601 to 620 of 726
  1. #601
    Oct 2013
    543
    Re: THE GRIZZ
    Jeff,
    Thanks for the video. I have done that same procedure repeatedly, right out of the box and over again after the crash and it still isn't reading accurately. I can get the concentricity dead nuts and adjust the nul to exactly zero and the thing still reads bonkers. It's off to Germany!
    Stuart
    "THE GRIZZ" photo album - https://goo.gl/photos/yLLp61jooprtYzFK7
    Youtube - https://www.youtube.com/channel/UCT2lq9obzEnlEu-M56ZzT_A
  2. #602
    Oct 2013
    543
    Re: THE GRIZZ
    Some photo "ketchup"....
  3. #603
    Oct 2013
    543
    Re: THE GRIZZ
    This was last Sundays project. Exercise in picking back up the geometry on the 2nd op, opposed to just hogging off the "hat" / remaining material.
  4. #604
    Oct 2013
    543
    Re: THE GRIZZ
    Off to the mother land! Looking forward to getting the "estimate" , the consensus seems they are "to costly to repair" but you will be hard pressed to find any true answers on the matter. Call it a surprise.....shall let you know in a few months! = )
  5. #605
    Oct 2013
    543
    Re: THE GRIZZ
  6. #606
    May 2011
    308
    I though we all agreed you were gonna put the Haimer away for a while. Carefully put it back in the box and slowly walk with it to the garage trophy shelf.
  7. #607
    Oct 2013
    543
    Re: THE GRIZZ
    Matt,
    We melted all the trophies down to make money to send the busted Haimer back to Germany. The Haimer that we're currently using seems to measure accurately enough to pick up the part after flipping it so there are no noticeable machining lines...maybe its crash wasn't as severe as the other one was.
    It's amazing how many chips a simple little part will generate. It's also interesting how a slight change in speeds and feeds can make the chips much less 'pluggy' for the drain screens. The chips in the firsts experiments were like fine hair and slowed the drains down considerably. After Nick got a bit more realistic in his speeds and chip loads, the coolant just sails through the screens.
    Early on in this build Chris (Icvette) make a comment about building a chip conveyor into the enclosure during its construction. The general consensus was that might be overkill for a small hobby machine like this, but I will admit, it might have been a viable scheme after seeing how many chips even a small job generates.
    Stuart
  8. #608
    Nov 2007
    2151
    Re: THE GRIZZ
    Quote Originally Posted by atomarc View Post
    Matt,
    Stuart
    Easy to make mess of chips machining parts 2x2 or larger! When performing the normal operation to mill off the top of part to height. I tend to setup back to front and left to right tool paths to send all the swarf to the easy side of my machine for clean up. Something to consider anyway.
  9. #609
    Mar 2017
    409
    Re: THE GRIZZ
    I just wanted to say, it is hard to believe that these are pictures of the same machine. Way to go.
    You have done a fabulous job with the upgrade.
  10. #610
    Oct 2013
    543
    Re: THE GRIZZ
    Mr. Sponge,
    What great pictures, thanks for the 'before & after'. It is hard to believe, but of course I have lived every nut, bolt and wire so my view is a bit skewed. Lots of water (and $$) under the bridge between those two photos.
    I think the one feature I like most on the machine is the power draw bar. I cannot imagine swapping tool holders using a wrench.
    Stuart
  11. #611
    Aug 2008
    962
    Re: THE GRIZZ
    Stuart,
    I felt like the chip auger was a bit overkill too, but I did it anyway and am now glad I did ..
    Being experienced machinists you may already know this, but It was a real game changer for me ..
    If you're able to walk away from a messy machine after finishing a job .. the chip clean up is WAY EASIER the next day after it's dried out.
    Gary
  12. #612
    Jan 2013
    630
    Re: THE GRIZZ
    So awesome to see it dirty and making stuff.
  13. #613
    Oct 2013
    543
    Re: THE GRIZZ
    Gents,
    Thanks for the positive comments and the suggestions. Currently, Nick is doing just as Gary suggested...mounding the chips on the sloped sides of the enclosure and letting them drip-dry overnight, then it's a pretty straightforward cleanup.
    Stuart
  14. #614
    Feb 2014
    227
    Re: THE GRIZZ
    Nick, the mill looks awesome and from the videos it is doing a great job! If you would not mind, how many lbs. of holding force are your belleville springs producing and how did you stack them? It looks like you are using TTS tool holders like myself. By the way, My Haimer Zero Master is not set right on the 0 mark either. The small needle is just barely off.
    Jeff
  15. #615
    Oct 2013
    543
    Re: THE GRIZZ
    Jeff,
    I'll answer for Nick if i may,
    Thanks for the positive comments. If you look at our post #73 you will see the Bellevilles and how they are stacked. They give us a little over 4000 lbs of pull on the toolholder. This obviously required some type of drawbar that can compress that force to release the toolholder, hence our air-over-hydraulic intensifier and home made hydraulic cylinder.
    With only 50 psi of air, the intensifier when can develop over 4700 pounds of squeeze on the drawbar to release the tool. If we mistakenly applied 100psi to the system we could get almost 10,000 pounds at the cylinder, which of course would be the end of the Grizz for sure..
    On the Haimer, the little instruction sheet that came with our ZeroMaster shows the simple procedure to adjust the 'nul'..meaning the adjustment to align the indicator hand with dead zero at rest. Have you tried that, it's simple and done without digging into the instrument.
    Stuart
  16. #616
    Oct 2013
    543
    Re: THE GRIZZ
    Big thank you to friend "CS900" !!!! Super awesome!! The care package of regrind end mills is amazing. Truly appreciated.
    - Nick / Stuart
  17. #617
    Aug 2006
    673
    Re: THE GRIZZ
    I want to see the long one in action on the grizz!
  18. #618
    Oct 2013
    543
    Re: THE GRIZZ
    Quote Originally Posted by CS900 View Post
    Cliff,
    Nick says he has a piece of Kryptonite all lined up to cut down with that 'long mother rougher'
    Stuart
  19. #619
    Aug 2006
    673
    Re: THE GRIZZ
    Cliff,
    Stuart
    I for one, look forward to that video!
  20. #620
    Feb 2014
    227
    Re: THE GRIZZ
    Stuart, I got the Belleview springs figured out for the drawbar. I appreciate your help. I have a question for you. I had a drawbar turned on a lathe from a machine shop as I did not want to use all thread. I thought that the all thread draw bar was bent, well it was not. The TTS collet I was using was actually .023 out of round in other words the center of the hole was not concentric. We put the draw bar in the lathe chuck with the collet attached and it was pretty sad to see. Well that carries up to the belleviews and to the draw bar nut. I tired a different Collet from lindsy and even a bridgeport, same thing.
    Out of all that rambling on, did you have a problem with yours of did you use some kind of centering taper like on a bridgeport to center the draw bar in the spindle?
    Jeff
  1. enough yapping---grizz x3 //ordered// RECEIVED
    By project5k in forum Benchtop Machines
    Last Post: 01-09-2008, 11:50 AM
