587,905 active members*
3,640 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > okuma macturn osp10l
Results 1 to 13 of 13
    Oct 2016
    16
    Red face okuma macturn osp10l
    Hi has anybody programed taillstock for okuma macturn , I can't understand how programed in automatically. I dont know how to programmed joint on , M189.
    i use G152 W100 but joint does want came out, something I missing. sorry for english. hard to explaned.
    Oct 2016
    16
    Re: okuma macturn osp10l
    Osp-e10l
    Išsiųsta naudojantis LG-D855 Tapatalk 4 Lt
    Aug 2011
    423
    Move Turret X axis to positive limit.
    "Imagination is more important than knowledge."
    Oct 2016
    16
    Quote Originally Posted by kurmay View Post
    Thanks.I will try.
    Oct 2016
    16
    No,it not working. I have that alarm when I want to move taillstock. I use code g152 w.... And alarm this....
    Apr 2006
    825
    Going Waaaaay back in time... I worked on an Okuma LC20-M that had a programmable tailstock.
    I recall that you had to ZERO-SET the W axis position inline with the connection position.
    Had to manually align the pickup pin with the middle of the slot on the tailstock, i.e. wind the Z along until it was in position, manually extend the tow along pin (button on the control panel) and then move the tailstock forward or backward and then move in the opposite direction by 1.5mm to get the pin in the middle of the slot, there was 3mm backlash between the pin and the slot. Zero the W axis with what ever value you needed and away you went.
    Beyond that memory... nothing.
    Hope that kind of helps in some form.
    Brian.
    Oct 2016
    16
    Thanks I will try on Monday.
    Oct 2016
    16
    Quote Originally Posted by broby View Post
    Brian.
    Maybe you have exzemple program.
    Oct 2016
    16
    Quote Originally Posted by Motiejunas View Post
    because I do not know how to accurately write. I will try set zero.
    Apr 2006
    825
    Sorry, when I stated it was way back, I mean over 20 years ago!
    The machine is long gone, sold for scrap I think, but might have the relevant manual still hanging around. I will take a look on Monday, but no promises.
    Oct 2016
    16
    Thanks any way.
    Oct 2016
    16
    I discover how it works. Yeep......
    Apr 2006
    825
    Well done!
  1. Okuma Macturn 550W
    By macturn550w in forum Tormach Personal CNC Mill
    Last Post: 08-04-2016, 12:17 AM
  2. Replies: 1
    Last Post: 08-03-2016, 03:19 PM
  3. Okuma Macturn 350 OSP100
    By Green Button in forum Okuma
    Last Post: 05-03-2011, 01:55 PM
  4. Balance turning in Okuma Macturn
    By zooloader in forum Videos
    Last Post: 09-29-2010, 09:31 AM
