587,743 active members*
3,062 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Homann Designs TM20LV (BF20,G0704) conversion
Page 15 of 16 513141516
Results 281 to 300 of 303
  1. #281
    Aug 2005
    1105
    Re: Homann Designs TM20LV (BF20,G0704) conversion
    I engraved a few more nut, but have quite a few to go and am really happy with the outcome. One of the advantages of engraving the nuts, is that the holder can be reassigned to another number by changing the nut.
    I still need to work out what to do with the holders that don't have nuts. I may use CNC Wrapper and engrave the number on the circumference of the holder, but for the moment, I'll keep using the stickers on them.
    Cheers,
    Peter
    Homann Designs - http://www.homanndesigns.com/store
  2. #282
    Aug 2005
    1105
    Quote Originally Posted by Neptunes View Post
    No problem will ask my wife the name tonight as she was looking for my sons school project playing guitar on stage. Just needs to be see through red Perspex or similar we might even have some how big do you need it ?
    I don't need much, just enough to cover the rpm display. Something like 100mm x 50mm should be plenty.
    Thanks,
    Peter
  3. #283
    Aug 2006
    673
    that's a great idea for the tool holders....I may steal that....Great job.
  4. #284
    Aug 2005
    1105
    You'd better hurry,my patent application is almost done.
    Cheers,
    Peter
  5. #285
    Apr 2015
    48
    Hey Peter so after speaking the wife had the same problem as you only 3mm but the ladies found iPad 2 cheap plastic covers in a 2 dollar shop and cut them up only thing was they only come in green, yellow, blue and red hope that helps I will check out the shop on Friday if they have any left will post on to you.
    Cheers
    Peter
  6. #286
    Dec 2009
    1416
    Ok, I am totally going to rip off the idea of putting that on the front of the mill. I just need need a spindle on/off and speed up/down buttons and maybe a start/abort. That would be awesome.
    CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
  7. #287
    Aug 2006
    673
    Quote Originally Posted by phomann View Post
    Cheers,
    Peter
    looks like i have a weekend project
  8. #288
    Aug 2005
    1105
    Cheers
    Peter
    Thanks Peter. I'll have a look around as well. With all the LED displays around, I'd have expected that it would be easy to source.
    Cheers,
    Peter
  9. #289
    Aug 2005
    1105
    Quote Originally Posted by photomankc View Post
    The most difficult bit is lining up the existing mounting holes on the mill head. On my will they were all hand drilled on various angles. My backup plan was to drill new mount holes, hidden under the orange panel. For that though I'd have to take the mill head off the mill to use the drill press, otherwise they would be as out of alignment as the original ones.
    Cheers,
    Peter
  10. #290
    Aug 2005
    1105
    Quote Originally Posted by CS900 View Post
    I'll be doing some more over the weekend myself.
    Cheers,
    Peter
  11. #291
    Aug 2005
    1105
    Hi all,
    I was playing around with the new touch today. I made a new "short" cable to run to the socket on the front panel.
    https://www.homanndesigns.com/index....roducts_id=347
    Cheers,
    Peter
  12. #292
    Nov 2009
    4415
    Nice addition. Does it disable the spindle once the probe is plugged in? ;-)
    A lazy man does it twice.
  13. #293
    Aug 2005
    1105
    Interestingly, as soon as I plugged the cable in, I thought "That's going to make a mess if the spindle starts!"
    No it doesn't. If I used a 4 pole connector on the PCB I could detect when the cable is plugged in, and with a bit of circuitry use it to disable the VFD.
    I'm not going to put the effort to design that in. Well not until I start the spindle with the probe in and wreck everything.
    Cheers,
    Peter
  14. #294
    Aug 2005
    1105
    Quote Originally Posted by Fastest1 View Post
    After a bit more thought on the matter, I'm going to add it in.
    Cheers,
    Peter
  15. #295
    Dec 2009
    1416
    Cheers,
    Peter
    Awwww, what fun is that!?! You're supposed to learn these things the hard way like I love to do.
  16. #296
    Nov 2009
    4415
    I like the fact he implemented a good idea that really started as a joke. Safety if cheaply attainable is best. I might even be a consumer of another of his products ;-)
  17. #297
    Dec 2009
    1416
    Yep, and the safety interlocks you don't have to think much about are the best kind. That's why I like this site. I'd likely never think of that either until a mishap enlightened me.
  18. #298
    Jun 2011
    692
    I think there are also 1/8" jacks with a switch on them to mechanically detect when something is plugged in. They're what laptops and cell phones use to mute the speakers when you plug your headphones in.
  19. #299
    Aug 2005
    1105
    Hi All,
    Well it's been a while, I've done a few improvements on the mill. I've been using it a lot. It is probably ready for a double nut ballscrew upgrade.
    I did the revision of the I/O status board on the front of the mill. The main upgrades were;
    1. Added an optoisolated switch that is activated when the phono jack is plugged in.
    2. Added a 2nd phono jack. They both activate the same input 4, but one is active hi, the other active lo. I got fed up with having to change the Mach3 configuration whenever I changed from the touch probe (N/C) to the tool offset plate (N/O).
    3. Both of the phono sockets are stereo sockets. I did this so that a stereo jack can be used to supply 12 volts to whatever is plugged into it. As a consequence I've added switches to turn off the 12V when mono jacks are used. I've also added a poly fuse so things don't smoke if a mono jack is plugged in with the 12V supply switched on.
    The GC-10 board is basically a general purpose I/O board for the Geckodrive G540. On the bottom right you can see the relay switch outputs. They can be used in various setup to disable the spindle when a phono jack is plugged into the board.
    Cheers,
    Peter
  20. #300
    Aug 2005
    1105
    The image below shows the GC-10 board mounted into the aluminium plate along with the original TM20LV mill tach0. You can see the relay outputs wired into the Input 3 input. (blue ferrules)
    The two tone plastic is glued to the 1mm aluminium plate with supper 77 spray adhesive prior to engraving and cutting.
    Cheers,
    Peter
  1. Optimum BF20 G0704 Conversion
    By Winnfield in forum Benchtop Machines
    Last Post: 08-07-2011, 12:16 AM
