587,752 active members*
3,716 visitors online*
IndustryArena Forum > CAM Software > Vectric > EPIC fail on 3d relief Need help!
Results 1 to 12 of 12
    Aug 2017
    5
    I made my first 3d relief, I have attached the pics on the rough in and the finish. The rough in looks good but the relief is well going down. Please help
    35538
    Re: EPIC fail on 3d relief Need help!
    What does the Aspire preview look like?
    Is that finish pass complete?
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Aug 2017
    5
    Looks great, normal anyway yes finish complete. Wish I could attach the aspire file
    35538
    My guess is that you're Z axis is losing position.
    Are you sure that you are using the same tool for finishing that the toolpath calls for?
    Gerry
    Aug 2017
    5
    Yes
    Feb 2012
    149
    Quote Originally Posted by JJCR View Post
    Looks like your finish pass took away too much material. (The area for the fish tail should not be so deep. It should be approximately the same height as your rough pass). Did you zero to original surface after the tool change?
    Or perhaps as ger said wrong tool (the perimeters of the model shouldn't be so rough with uncut material. Did you use a tapered ball nose cutter on finish?).
    Sent from my SM-T813 using Tapatalk
    Aug 2017
    3
    Are the z values in your g code correct? If they are and your tool length was right (no offsets?) then maybe it slipped? Or perhaps you accidentally programmed it with a straight bit instead of a ball. That could produce some strange results, but I'm not it would look like that. This stuff can be frustrating man, I know. I hope you figure it out.
    Apr 2004
    5751
    It doesn't look too far off, really. You probably used a larger tool that you need to get the fine detail. And you neglected to tell it to remove the ambient area around the carving; that's why it appears to be sunken rather than raised.
    Andrew Werby
    Website
    Jun 2008
    562
    Post this on the Vectric site and you will get more help here:
    Vectric Forum ? View forum - Aspire - General
    35538
    Cut your acceleration and velocity settings in half, and try again.
    Gerry
    Jun 2008
    562
    Quote Originally Posted by Jmhx2 View Post
    Ditto, it "almost" looks like your tool was rezeroed in the bottom of the roughing pocket instead of the top of the material.
    Aug 2017
    5
    Well I figured it out after making serious firewood. I was using 1.5 on my depth, should have been -1.5 the learning curve for me is steep lol
  1. HSM Miserable fail.
    By Jon.N.CNC in forum Autodesk CAM
    Last Post: 09-30-2015, 07:14 PM
  2. Epic CRP4848 Build Thread!
    By TerribleDamage in forum Avid CNC
    Last Post: 09-22-2014, 08:42 PM
  3. Font Fail
    By jrmach in forum BobCad-Cam
    Last Post: 02-12-2013, 07:54 AM
  4. 325 PROC WDT FAIL
    By ramsey321 in forum Tree
    Last Post: 09-14-2010, 04:47 PM
  5. EPIC Programmer
    By drawbar in forum PIC Programing / Design
    Last Post: 10-10-2005, 10:16 PM
