587,772 active members*
3,490 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Tool holder interchangeability between machines.
Results 1 to 10 of 10
    Jun 2012
    21
    So whats your opinion on setting up an interchangeable tool library ... if that makes sence.
    Im looking at getting a 440 (or 1100 if funds allow) at some stage in the future but in the mean time im considering the Optimum BF 30 (as a manual mill) with the MT3 taper.
    Tormach do a MT3 taper to TTS but Id ideally perfer the BF46 but as I havent seen the a ISO 40 (DIN2080) to TTS I assume id have to have one made up (I dont have grinding capabilities)
    Whats your opinion on having tools that all share the same tool holder or can be used with an adaptor ? Is it a dream or a option worth doing ?
    Regards
    Apr 2013
    1788
    Re: Tool holder interchangeability between machines.
    I don't see any particular advantage of sharing holders. Using a MT3-->TTS or other adapter will mean more stickout which means less rigidity and less Z-axis room than mounting the tools directly with your manual mill. If you damage a cutter with the manual mill you will have to remember to remeasure and set the correct offset on the Tormach and if you're like me you'll forget with unpleasant consequences! When I had a manual mill I found it convenient to mount all tools in an R8-->ER40 adapter. Just a few considerations...
    Jun 2012
    21
    Thanks for the reply and food for thought.
    I suppose im trying to save on tooling or better save money to be able to afford more tooling.
    I had thought that about tool length offset but hadnt even registered about rigidity and reduced Z height.
    On the R8 taper (which would be ideal) thats Bridgeport territory which is just too big at the minute for me. I dont think any of the optimum stuff is R8. Are their any good bench top mills running R8 ?
    Apr 2013
    1788
    The term "good" has a range of meanings but there are numerous manual mills with R8 spindles available in the UK. I've had no personal experience but suppliers such as Chester (MILLING MACHINES) list a variety of R8 capable machines. For example, their Lux, Eagle 30, 626, 830VS and others are available with an R8 spindle.
    Nov 2013
    402
    Why not just stick with an R8 spindle?
    A majority of manual mills use R8, as well as TORMACH.
    I run R8 in my Millrite manual mill, and in my Tormach 770, and my tooling is completely interchangeable between the two.
    Apr 2013
    1788
    Do you use TTS in both?
    May 2016
    138
    I have a LMS manual mill with tormach's R8 adapter in it and use the TTS on both that and my 1100.
    I started using the TTS when I just had the LMS mill because I knew I was moving to a tormach at some point, this saved me a bit and I had a nice stockpile of holders when I got my Tormach.
    Nov 2013
    402
    I could, if need be.
    TTS is nothing more that 3/4" shank tool holders.
    Just use a 3/4" collet for them, and they're completely interchangeable.
    Jan 2007
    1332
    I share TTS toolholders with my Tormach 1100 and Rockwell manual mill. Both have R8 spindles.
    Don
    Mar 2009
    1863
    I would stay far, far away from any machine with a MT3 spindle unless you're talking about a drill press.
    I made my own collars for 3/4 inch shank tooling. I made them out of 6061 aluminum and I made the hole in the collar .003 smaller than the 3/4 inch shank on the tool. Then I heat the collar with a propane torch, drop it on to where I want it and then squirt some water on it to cool it.
    With a .003 interference fit there's no way that collar is going ip move.
  1. Bridgeport boss 6 quick change tool holder not holding tool properly.
    By TBCind in forum Bridgeport / Hardinge Mills
    Last Post: 04-04-2017, 06:56 PM
  2. Servo drive interchangeability
    By NITROCHUCK in forum Servo Motors / Drives
    Last Post: 12-15-2016, 01:57 PM
  3. Vertical lathe tool holder for Tormach Tool System.
    By TXFred in forum News Announcements
    Last Post: 08-18-2014, 09:20 AM
  4. Replies: 10
    Last Post: 11-06-2012, 11:43 PM
  5. New (3) Three Position ID Tool Holder for CNC Swiss-Type Machines
    By SwissType1 in forum News Announcements
    Last Post: 09-23-2010, 08:32 PM
