587,735 active members*
2,834 visitors online*
Results 1 to 3 of 3
    Mar 2013
    48
    Chinese 4th axis
    Has anyone here had experience with these? Here's an example:
    CNC Hollow Shaft 4th Axis Router Rotary Φ100mm 4 Jaw Chuck+MT2 65MM Tailstock | eBay
    I'm thinking about getting one but replacing the stepper with a continuous-rotation variable speed motor to use it more like a lathe, up to around 1000 rpm. I'm curious about the quality of the bearings and whether they are suitable for this, or whether these are meant more just for indexing.
    Many thanks!
    Sep 2006
    6463
    Re: Chinese 4th axis
    Hi, most faults I have read about the cheap Chinese belt drive type 4th axes are in the stepper drive that is as weak as a kitten.
    I doubt that the 4th axis types on EBAY have angular contact or taper roller bearing with preload capabilities, probably only deep groove radial types, so if you do a lot of fast revolving with axial loading you'll get some bearing wear and end movement that cannot be corrected.
    You could rebuild one with better bearings and a stronger stepper motor, but it'll cost you almost double.
    Ian.
    Mar 2013
    48
    Okay, I suspected that might be the case. Thanks for your time!
  1. Chinese router 4th axis
    By hokkaju76 in forum Chinese Machines
    Last Post: 11-16-2016, 07:47 PM
  2. Chinese 5 axis problem
    By cthomas46703 in forum LinuxCNC (formerly EMC2)
    Last Post: 06-10-2016, 07:50 PM
  3. Chinese 4 axis router 4th axis configuration
    By CodeInTheNode in forum Mach Mill
    Last Post: 01-09-2016, 09:12 PM
  4. I need a chinese 4-axis controller for $150 or less
    By TheGyrator in forum Chinese Machines
    Last Post: 12-24-2014, 03:09 AM
  5. Chinese 3040 CNC with 4th Axis
    By Winterdragon in forum Stepper Motors / Drives
    Last Post: 01-28-2014, 05:02 PM
