587,372 active members*
4,047 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > pls, a code sample for double OD Y holders :)
Results 1 to 16 of 16
    Jun 2015
    4156
    hello, please, i need an example for OD turning with double holders
    Y axis changes between tools lb3oooex2 osp3oo
    and how can i gauge those tools, since gauging with "Y on" fails ? kindly !
    Ladyhawke - My Delirium, https://www.youtube.com/watch?v=X_bFO1SNRZg
    Jun 2015
    4156
    Re: pls, a code sample for double OD Y holders :)
    turning works fine with G138 Y...
    ... but i can't measure tools ... i wish VBZOY was not readonly, or something
    Jul 2010
    287
    Stop putting the machine in G138.
    Leave it in G136 and instead command "G0 Y1" or whatever the Y distance is you're after.
    in manual mode i believe you'll get an alarm D but you can still touch off your tools.
    you can also give it a y axis offset instead and call up the tool and a position in X. It will bring the tool to Y0 by default since that's where the machine was without the y offset active.
    Then just touch off like normal in manual mode.
    I don't believe there's any such thing as VBZOY. I believe that is a parameter known as Y axis turning position or something.
    On the P200s it was a read/write variable, and on machines we didn't have Y axis turning on we'd lie to the control, change that number and change it back when we were done.
    On the P300s they took that away so you need the Y axis turning option.
    also, in your programming you will not be in G138 for a Y axis tool either. You will command a Y axis in the program or have a Y axis offset value set for each Y axis tool.
    Jun 2015
    4156
    Stop putting the machine in G138. Leave it in G136 ...
    hello again tea hole this code :
    G136
    T
    Goo X0 Z2.5 Y9 > will not raise the Y, also there will be no errors
    if i replace 6 with 8, than all will be ok works on my Y lathe
    and when i remeber that it was you who showed me these VBZO* variables ; pls check attached image from the file shared in #1 : http://www.cnczone.com/forums/okuma/...able-list.html
    VBZOY shares same content as the base_o_offset_for_y_axis from system_para : if the value is edited inside the parameters, than the axis shift and i can measure the tools, but this involves editing the parameters, and that is a danger zone for the operators
    if VBZOY was not read-only, than i could develop a faster way to shift the axis, like defining a G/M macro code
    On the P200s it was a read/write variable ...
    please, can you dig for this and share an example ? thcs
    ... i have tested a lot of variables, but not all
    i can not raise the Y without the G138 kindly !
    Jun 2015
    4156
    Quote Originally Posted by deadlykitten View Post
    yesteray i found a way to measure Y turning tools with 0.2 accuracy, but this involves some calculations
    it does not take long, but is a bit longer than lowering the senzor and measuring the tools
    this should be done once, at initial setup, because after that only inserts are changed, and only small corections take place ...
    however, i am still looking for a normal way to do this, but i see this no longer as an obstacle; maybe my dealer will reply on that
    now i am looking forward into merging this double Y holders with dynamic_indexing and offset_protection
    Aug 2006
    162
    the tool call for a double stack is the same as long as you call y0.
    put the y offset in the y off set position.
    you have to turn on the y axis to jog to centerline on the presetter, then turn it off to do your touch. it will give you the ya xis not in turning pos alarm but will do the touch.
    all my tool calls have the y0 call because i sweep drills to y and adjust turning tools to no nip condition
    as far as y measure offset goes , eyeball it to center place cutting edge under center, face, measure nip, dim/2, offsetaccordingly
    i generally delete all g138's unless i am doing propper y milling(rare)
    Jun 2015
    4156
    hy hacdlux
    ... Y offset <> 0
    ... Y axis ON
    ... T X Z Y0
    ... getting close to presetter
    ...... so far so good
    if i turn off the Y axis / G136, than the turret will lower at Y0, and i won't be able do to the touch
    if Y axis is ON, than i can't touch, because i receive the "Y on alarm"
    i generally delete all g138's unless...
    Y axis will not move without G138 / kindly !
    Jun 2015
    4156
    both of you : teahole & hacker_de_luxe told me to avoid G138
    but i can not call the tool ( T X Y Z ) without G138
    if you have the lb3000ex2 osp300, than maybe i am doing something wrong
    if so, please, can you share a code example ? kindly !
    Jun 2015
    4156
    this is how i measure X_offset for y_excentic tools :
    1) OD / X+ / senzor upper edge / P8
    ... reset
    ... raise / lower the turret at specific Y value
    ... feed by hand until tool is in contact with senzor ; beep beep beep sound
    ... go at X_offset :
    ...... CALL : will input actual X value
    ...... ADD : -97.5
    97.5 represent a diameter, where a corection with X_offset=0 is aligned with the upper edge of the senzor
    "diameter" is materialized by the "X_axis_value"
    "X_offset=0" is materialized by a "default id holder"
    in other words : 97.5 is the value on my lathe were the "center axis" of the "id holder" is aligned with the "upper edge of the senzor"
    this is represented in the attached images
    2) ID / X- / senzor lower edge / P6
    ... same as above, only ADD value changes : -67.5
    67.5 = 97.5 - 2 * 15, where 15 is the senzor edge ( the distance between upper and lower senzor edge )
    Jun 2015
    4156
    this is how i measure Z_offset for y_excentic tools :
    1) using a machined surface with known Z : if a knife machined a straight face ( Z=0 ), than call the tool and simply get close to that frontal;go in offset_menu, and press CALL inside Z offset + input 0 ( or the known Z value )
    2) using a machine surface with known Z : the spindle frontal
    3) using the senzor :
    3.1) frontal / Z+ / senzor right edge / P7
    ... reset
    ... go at Z_offset :
    ...... CALL : will input actual Z value
    ...... ADD : VSZOZ - 212.870
    212.87 is the distance between "spindle frontal" and "senzor right edge", as shown in attached image
    3.2) reversed frontal / Z- / senzor left edge / P5
    ... same as above, only ADD value changes : VSZOZ - 197.870
    197.870 = 212.870 - 15, where 15 is the distance between left and right edges of the senzor
    ... touch the senzor by feeding the wheel
    ... press CALL inside the offset_menu
    ... ADD a corection value
    ...... accuracy < 0.2
    it may be an option to use the senzor while Y is active; i still wait for a response from my dealer
    i insisted again today
    Aug 2006
    162
    okuma lb3000 myw osp 300 circa 2015
    (SUB SPINDLE DRILL)
    N5 G141
    G00 X30. Y0. Z15. T1100
    N5 T1131
    N5
    G97 S2109 M03
    M08
    G00 X0. Z.1 Y0
    M101
    G74 G95 X0. Z-.32 K0 D.42 F.012
    G00 Z.1
    M09
    M102
    M01
    y offset is irrelevant to me because i put them in the tool table. if you want to do it the other way y0 in the tool table and put it in the program. the way this is it doesn't matter what holder their in because y is set in the offset not in the program.
    Jun 2015
    4156
    hy hacdlux thank you for that sample, but it does not work 4 me ( attached images )
    what are M101 and M102 for ?
    please, will you share the content of "Ospmngcd.cnc" from your lathe ( c:\osp-p ) ? i wish to check the differences between lathes options; kindly !
    ps : those images are clear, because i cleaned the control screen yesterday with a bit of coolant ...
    Aug 2006
    162
    m101 and m102 are high pressure coolant codes
    its interestin though my y axis displays all the time.
    there is an option called "off center turning" you might be missing or its a parameter thing. you should talk to your dealers applications dept
    Jun 2015
    4156
    hy hacker i will discuss again with my dealer next week
    it has been a while since i started this thread, and meanwhile, the guy from the technical departement of our Okuma dealer left the country for 2-3 weeks
    other guys are not so sharp, and i am tired of pointless discusions
    at least i know that there is an "option" ; thank you
    Jun 2015
    4156
    hello, please is it possible to use G33 with the turret raised on Y ?
    ... i bought tools with smaller shank ( square 20 )
    ... i bought Y holders + finish touches :
    ...... screws to have same length
    ...... screws to stick out of the holder more, and at same distance as my actual holders
    ...... some i_dont_know_the_word to dont clamp the tool shank directly
    ...... coolant pipes
    ... i have written the code for this double holders
    but i can not put them on the machine, because there is a thread tool, and G33 is not workin with turret raised ... and dealer is frozen
    please :
    G97 S600 M3
    G138
    VTOFY[VETON] = -9
    G00 X100 Z2.5 Y0
    G33 X99 Z-50 F1
    kindly !
    Jun 2015
    4156
    hy teahole, hy hacdlux, it took a while for my dealer to figure it out that the Y-turning option actually exists
  1. C Axis Sample Code
    By cad-cam4me in forum Fanuc
    Last Post: 11-30-2016, 08:16 PM
  2. Anyone have sample Homing Code?
    By nelZ in forum LinuxCNC (formerly EMC2)
    Last Post: 06-06-2013, 01:38 AM
  3. Sample G-Code program
    By tward74 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-03-2010, 12:19 PM
  4. Sample 5-axis NC code
    By javed08 in forum Uncategorised CAM Discussion
    Last Post: 01-24-2010, 08:29 AM
  5. Asking for a G code sample
    By cstmwrks in forum G-Code Programing
    Last Post: 04-03-2006, 01:48 AM
