587,092 active members*
4,976 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Fusion 360 "Cutting" option using MACH3 mill generic post wont post!!!!
Results 1 to 2 of 2
    Aug 2016
    22
    Trying to drive my MACH3 CNC plasma machiine with Fusion360 "cutting" machining option. it gives me the lead in features i need. but when i try to post process it it fails???? I've posted many 3d adaptive clearing, engraving, slot, facing...................without issue. but the cutting wont work??????? below is what i get???? any help would be awesome.
    thanks
    Information: Configuration: Generic Mach3MillInformation: Vendor: Artsoft
    Information: Posting intermediate data to 'C:\Users\ricro\AppData\Local\Fusion 360 CAM\nc\logo1stplasma2.tap'
    Error: Failed to post process. See below for details.
    Code page changed to '1252 (ANSI - Latin I)'
    Start time: Friday, May 5, 2017 12:36:08 PM
    Code page changed to '20127 (US-ASCII)'
    Post processor engine: 4.2.1 41304
    Configuration path: C:\Users\ricro\AppData\Local\Autodesk\webdeploy\pr oduction\629757f22e01db34146388e207b7011b131e863a\ Applications\CAM360\Data\Posts\mach3mill.cps
    Include paths: C:\Users\ricro\AppData\Local\Autodesk\webdeploy\pr oduction\629757f22e01db34146388e207b7011b131e863a\ Applications\CAM360\Data\Posts
    Configuration modification date: Wednesday, March 1, 2017 10:30:22 PM
    Output path: C:\Users\ricro\AppData\Local\Fusion 360 CAM\nc\logo1stplasma2.tap
    Checksum of intermediate NC data: a3dbe41f38fba5ecb534157450c9331d
    Checksum of configuration: ce5fcda1268ea1ab0aeaf3d37040164e
    Vendor url: Newfangled Solutions » CNC Software Home of Mach3
    Legal: Copyright (C) 2012-2016 by Autodesk, Inc.
    Generated by: Fusion 360 CAM 2.0.2995
    Error: Waterjet, laser, and plasma cutting toolpath is not supported by the post configuration.
    Error: Failed to invoke 'onOpen' in the post configuration.
    Error:
    Error: Failed to execute configuration.
    Stop time: Friday, May 5, 2017 12:36:08 PM
    Post processing failed.
    Feb 2009
    311
    Re: Fusion 360 "Cutting" option using MACH3 mill generic post wont post!!!!
    It looks like your post processor is not setup for plasma/laser cutting. I've never tried it myself so I can't really be of much help. If you don't get any answers here try posting over on the Fusion CAM forum.
    https://forums.autodesk.com/t5/compu...-cam/bd-p/2070
    C|
  1. Fusion 360 Generic Fadal Post Output
    By megacanam in forum Fadal
    Last Post: 09-25-2016, 07:25 AM
  2. Replies: 0
    Last Post: 02-04-2014, 02:06 AM
  3. Replies: 21
    Last Post: 01-13-2014, 04:10 AM
  4. Replies: 5
    Last Post: 09-12-2012, 03:09 PM
  5. Pimp "my" generic post for TNC530
    By Lazy in forum Post Processors for MC
    Last Post: 05-11-2011, 08:20 AM
