I don't understand. Could you please explain "ability to shift XYZ during the program" and the problem that is being addressed?
If I understand what you want to do, maybe look at G52 for temporary offset.
Jeff
The desire is to be able to zero a new tool when you install it during a tool change.
Mach3 always allows you to move the table around so you can set a new tool z height during a tool change in the middle of a procedure. Pathpilot doesn't.
EDIT: never mind. That has nothing to do with "blending surfaces".
Tim
I've done changes on models and molds where I needed to blend to the surface without violating the surface. Having the ability to jog the machine while the cutter pass is running makes this process easier.
Non-conversational spot where I could just straight type in code.
Control of coolant in conv. screens
A better editor would be nice. I find the included one to be awkward.
That was a nice feature in Mach. There is a workaround I use ( actually have used a lot ):
1) Stop the program
2) Change or install a new tool enter the offset in the tool table - I use a separate height gauge, not a tool setter, but either would be ok.
3) reload the program, use 'FIND G30' to get the G30 just before the tool call for the 'changed' tool.
4) 'Set Start Line' and off you go.
You have to repeat some machining but usually won't scrap the part and you're not starting all over.
Would be nice if you could 'Set Start Line' at a safe Z from where you stopped and have coolant state and spindle state resume where you left off. With the above scenario you go back to the last G30 to get coolant and spindle working properly.
Does this mean that there is a V 1.9.9 coming soon? My V 1.9.8 still has the old shut down screen.
Terry
Until then, you can use https://konklone.io/json/ to convert JSON to a CSV. I just tried it and it works very well.
--Scott
"You can't teach stuff in a school that you would learn in real life unless the real life people are in charge of the school." - Gene Sherman
I would really like the ability to adjust the tool height offset during a tool change. Sometimes a tool needs adjusting.
I would like to see a whole lot more of the filename in the file listings on the left and middle screens.
Would be nice to be able to customize the UI, just like different colors and maybe even themes, fonts. I know it makes no difference and it is useless but I like changing things up sometimes.
Since I'm so slow at programming I really could have used a radius cutting feature.
Dave
